Removing the Rear Shock - Page 3 - Honda CRF1000L Africa Twin Forum
 4Likes
post #21 of 37 (permalink) Old 01-08-2017, 11:50 AM
The other question i have is with the progressive spring.
Hyperpro manual says to mount the progressive side up. The Honda manual saying to mount the progressive end down? Anyone that's done the swap have the definitive answer?
Apachesmith is offline
post #22 of 37 (permalink) Old 01-08-2017, 12:04 PM
I think you answered it yourself, if one is up and the other is down, then it really doesn't matter. When I disassembled mine the tighter coils were up on factory springs, so I put replacements in same way. For fork oil measurement, it's prior to the springs being installed and I used the oil level tool with syringe. Makes it so much easier to get correct/equal level. I actually put mine at 160 mm from top. I weigh more than what they are recommending suspension settings for. It's heavier weight oil, so lower height setting.
XR650RRider is online now
post #23 of 37 (permalink) Old 01-08-2017, 01:10 PM
180mm is on the spring.... seems very low?
post #24 of 37 (permalink) Old 01-08-2017, 01:12 PM
kari4711's Avatar
Once again I would recommend to follow the Hyperpro description and mount the springs in the direction explained by them.
(It's not visible by eye if the Honda springs have the same parameters as the Hyperpro springs).
kari4711 is offline
post #25 of 37 (permalink) Old 01-08-2017, 02:11 PM
No fork oil measurements are before spring is installed on both. The factory springs are progressive and the tight wound coils were up on mine upon disassembly. The manual states down and Hyperpro says up.
Their 180mm recommendation is allowing a little more air space (air is compressible), fork oil isn't. You'd prefer the valving did all the work but heavier weight oil is slower traveling thru shim stacks.
I made the tool that screws onto damper rod out of a 2' long 1/2" ODx3/8" ID tube, drilled 1/8" holes thru tube about 1/2" from end and welded a 10x1mm nut on same end. Allows you to stroke that rod up and down and the holes allow the oil to flow out of tube. It's necessary when trying to get spring compressed, so you can get holding tool on.
post #26 of 37 (permalink) Old 01-08-2017, 02:51 PM
Sorry just to confirm,
Did you measure 180 before or after the spring was inserted?
post #27 of 37 (permalink) Old 01-08-2017, 04:31 PM
I just checked the gauge and I set my fork oil level @ 170mm from top BEFORE dropping spring in.
I originally intended to go to 150mm from top but thought it would be easiest to add oil later than trying to remove it. I changed fork oil level several times on XR650R's and re-valved but I'm not planning on taking the Africa Twin thru knee-deep whoops in 4th wide open. I actually like the way it handles with 170mm but haven't really had it off-road but have had it on rutted, wash-boarded, sandy dirt roads and it handles all with ease and better than factory setup.
post #28 of 37 (permalink) Old 01-08-2017, 05:33 PM
Ok that's interesting as the hyperpro manual says to measure the gap after putting the springs in.... which is what I've just done.... I'm going to give them a call in the morning as I've had enough of their less than helpful instructions..... Thanks for your help.
post #29 of 37 (permalink) Old 01-08-2017, 08:01 PM
The Hyperpro manual I have on page 10 and it's on page 11 in the link that someone posted previously
"12 Fill the fork to the specified oil level (see frontpage: OIL LEVEL) The oil level (air chamber) is measured with the fork fully compressed and all the loose parts (preload bush, ring(s) and spring) removed. Make sure the fork is
compressed in the hydraulic lock; when the compressing becomes heavier,
push further until steel to steel contact is felt.
Maybe your reading the section for Upside down with separate cartridge, which isn't the forks you have.
In the Honda Service Manual page 17-22, shows same thing. Spring, spring collar, spring seat and the cap are all removed and you fully compress the fork, seal will bottom out, then let it set after you've stroked it multiple times to get air out and then measure oil level with it sitting vertical and level.
post #30 of 37 (permalink) Old 01-09-2017, 03:56 AM
I was using USD separate cartridge - I had assumed the cartridge instructions were for the full hyperpro setup including their cartridges.
On my manual and the one posted earlier the detail you describe is under USD with cartridge and is on page 7.
Could you confirm I should be using the USD with cartridge for my reference?
Thanks for your assistance
A
Human Verification
Rear suspension replacement NetJack Wheels, Tires, and Suspension 11 02-24-2017 04:14 AM
Rear suspension sag setting xsilvergs Wheels, Tires, and Suspension 24 12-23-2016 11:02 PM
Radiator Guards and Rear Rack SkipD Appearance & Body 2 12-20-2016 05:58 AM
Windscreen removing Mad Frosty Appearance & Body 17 06-12-2016 11:10 AM
Rear inner tube Tinpot Honda CRF1000L Africa Twin General Discussion Forum 13 03-19-2016 05:22 PM
