Rapid bike programmer - Honda CRF1000L Africa Twin Forum
 10Likes
post #1 of 19 (permalink) Old 12-05-2016, 08:55 PM Thread Starter
Has any one try a rapid bike programmer from Rapid Bike/Dimsport?
Looks like they have three models. EASY,EVO,RACE.
Bike runs excellent, but do have a Arrow full TI exhaust and would like fine tune it.
rusty1 is offline
post #2 of 19 (permalink) Old 12-05-2016, 11:59 PM
I have this controler on my crf250l.
They now have one for our bike.
http://www.electronicjetkit.com/Dirt...number=8120173
paulwb99 is offline
post #3 of 19 (permalink) Old 05-22-2017, 11:23 PM
I've just installed the Rapid bike easy. Like the name implies, installation was very simple. The bike now has a stronger idle and I can't get it to hesitate/jerk at low rpm. Off idle response now feels like that of a carbureted engine, ie. **** smooth. All in all a great purchase. I run a stock exhaust btw. The rapid bike easy has a setting for standard and after market exhausts.
eltel62 likes this.
Benjah is offline
post #4 of 19 (permalink) Old 05-23-2017, 05:54 AM
jmf72's Avatar
Hi,
What's the difference with the BoosterPlug?
Do they do the same thing?
Cheers !
jmf72 is online now
post #5 of 19 (permalink) Old 05-23-2017, 06:01 PM
I'm no expert but my understanding is that the booster plug tricks the ECU to adding more fuel by telling it the temperature is 30 degrees lower than it really is. The Rapid bike easy is a little more sophisticated in that it intercepts the oxygen sensor output and adjusts it using a micro controller. I believe they both work well but the booster plug is a real bear to install (need to remove tank air box, some fairing ..) where the rapid bike easy requires almost no dismantling( Just the back seat and possibly the brake pedal depending on your bikes setup). They cost about the same so I went with the rapid bike option. I have removed the fairing once before when installing GPS power and a 12 V AUX power and swore never to do it again. It does not like to be removed..
eltel62 and Guyzer like this.
Benjah is offline
post #6 of 19 (permalink) Old 05-25-2017, 06:47 PM
eltel62's Avatar
Hoping to pick one up next week, were there any recommended settings on the dials for the stock setup?
eltel62 is online now
post #7 of 19 (permalink) Old 05-27-2017, 05:44 PM
Yes. Make sure you get the latest version of the manual online. You can download it from the ruggedroads website. There are custom settings for the AT.
eltel62 likes this.
Benjah is offline
post #8 of 19 (permalink) Old 05-28-2017, 08:12 AM
http://ruggedroads.co.uk/WebRoot/Sto...000_-_EASY.pdf
Here is the install guide. Setting are at the bottom for stock and after market set up. Any one know what he first dial does ?
eltel62 likes this.
CaptainAFRICA is offline
post #9 of 19 (permalink) Old 05-29-2017, 04:16 PM
Yes I'd like to know what it does too. Perhaps it's something to do with the gain on the PID controller?
Benjah is offline
post #10 of 19 (permalink) Old 06-16-2017, 11:23 AM
eltel62's Avatar
Rapid Bike Easy
Fitted my Rapid Bike Easy today, a little fiddley but not bad at all. I found lowering the bash plate on its hinges and removing the brake pedal helped a lot. It allows you to get your fingers in to release a little plastic clip that holds the current connection in place down by the o2 sensor. You need to release that connection from the bracket to be able to unplug it to insert the Rapid Bike cable black connectors, the bike has to be cold to do this for obvious reasons.
Once cabled in the instructions tell you to run the bike to get the o2 sensor hot which should flash the LED on the unit proving it is working and you close it up. Ten minutes later with the fan running on the radiator I had no flashing LED, just solid, in my case it needed a good ten minute run out on the road to get it to do so.
From start to finish it took me an hour, if I did it again probably 20 mins, no need to remove the tank. I only went for a short run but initial impressions are good, I am not really looking for more power, just trying to get rid of the low speed jerkiness of the engine which it does. I felt the pickup was smooth and strong but unless riding back to back it is difficult to be really subjective, longer rides will help me evaluate. Tools required, 12mm spanner for brake lever bolt (remove the bolt all the way, it keys onto the gear shaft), underseat allen key for bash plate (stock Honda).
ID:	26201   Click image for larger version
ID:	26209   Click image for larger version
ID:	26217   Click image for larger version
Q-Ball likes this.
Human Verification
Bike Magazine's Bike of The Year 2016 - Honda Africa Twin S4MST3R Honda CRF1000L Africa Twin Reviews 4 11-01-2016 01:08 PM
