Stall issues - Honda CRF1000L Africa Twin Forum
post #1 of 4 (permalink) Old 12-16-2016, 09:24 AM Thread Starter
Stall issues
Anyone have an issue when blipping the throttle and the bike wanting to stall or stalling? I noticed it when down shifting that it would momentarily cut off but stay running. Then I was seeing if it would do it again yesterday while riding and with the clutch in while moving it cut off completely at about 30mph. Its just when I give it a quick sharp twist. But it doesnt do it when I rev it longer and higher.
My bike is a 16 manual. It has about 400 miles on it as I just got it 2 weeks or so ago.
Just wanted to see if anyone else had this issue yet? I didn't see it when searching through the threads.
bdraughon is offline
post #2 of 4 (permalink) Old 12-16-2016, 04:11 PM
I have had some backfiring through the throttle bodies but not excessively so. I have also seen mention of stalling here and there. There is a suggestion that doing the ECU reset will cure this. I am not 100% sure how this is done with this particular motorcycle but look it up on the web and I am sure You will get the answer. With my former 690KTM it entailed a tickover for 15 minutes from cold without touching any controls.
The other suggestion is a possible problem with the start/kill switch.
6986 is offline
post #3 of 4 (permalink) Old 12-17-2016, 06:05 AM
Denburger's Avatar
Yea, mine did it once at about 400kl, never had it happen again, go figure?
I think the more I ride it the better I subconsciously understand it and adjust to it..
The Burger.
Denburger is offline
post #4 of 4 (permalink) Old 12-18-2016, 11:11 AM
xsilvergs's Avatar
Is this related to the MAP sensor tube being too short or kinked. The tube was replaced on mine and helped starting and erratic idle. Ask your dealer.
xsilvergs is offline
Human Verification
Honda Customer service/Warranty issues doug Honda CRF1000L Africa Twin General Discussion Forum 8 09-13-2016 12:24 AM
Replace with
