Could someone post the Dct reset procedure please - Page 2 - Honda CRF1000L Africa Twin Forum
 4Likes
post #11 of 17 (permalink) Old 06-14-2017, 12:32 AM
james.mc's Avatar
Originally Posted by mike5100 View Post
.......Sorry but having recently and reluctantly purchased the DCT, I am very interested in any possible issues.......
Eh? Why the reluctant purchase of DCT? There is a manual option as, I'm pretty sure, you will be aware.
regards
James Mc
Almost: 2017 CRF1000L DCT at the dealer with my name on it!
Current: 2008 Triumph Tiger 1050
Previous: 2003 Honda Varadero XL1000V (bought 2003, Sadly left behind in Europe)
james.mc is online now
post #12 of 17 (permalink) Old 06-14-2017, 03:29 AM Thread Starter
Here's the correct procedure from the AT manual with thanks to my dealer in Newcastle for providing them:
PS Looks like you don't touch the throttle but it is important to get the bike fully up to working temperature.
james.mc likes this.
mike5100 is offline
post #13 of 17 (permalink) Old 06-16-2017, 07:06 AM
james.mc's Avatar
If your Africa Twin has manual gearbox ignore everything below
For those that might prefer a text version of the procedure (above) I’ve taken the time, on nightshift to copy/write it up I’ll also attach a copy (DCT_Reset_Sequence_CRF1000L_DCT.txt) to this post for easy download.
Many thanks to mike5100 for providing the procedure in image form. Note, in Mike’s posts there are two images that make up the whole procedure.
Note, unlike some DCT procedures for other Honda DCT bikes (thanks again to mike5100 for pointing this out) there is no mention of throttle position so ‘assume’ that the throttle should be left alone for the reset procedure.
DCT Reset Procedure for CRF1000L DCT
1) Warm the engine up to normal operating temperature (Engine oil temp 50-110C / 112-230F) then STOP it.
Note: If the large “L” (extremely low oil temp indicator) or small “L” (low oil temp indicator) is displayed on the shift indicator then the engine must be warmed up further before proceeding.
With the engine warmed up and STOPPED —->
2) Turn the Ignition Switch ON (with engine stop switch in the run position) (do not start the engine) whilst at the same time holding down D on the N-D Switch. Keep holding the D switch on. The MIL will then come on. Wait until the MIL goes off and release the D switch.
3) Operate the N-D switch in the following sequence:
Push D then release
Push D
Push N
Push D
Push N
The PCM is ready to initialise the ‘clutches learning process’ when the “D” and “S” indicators light up AND the “_” is displayed on the shift indicator AND blinks at 2 second intervals.
Note: If at any point you get the Low oil temp indicator (“L”) come on, stop the process. START the engine, warm it back up to operating temperature (so that no low oil temp indicator is displayed), STOP the engine and repeat steps 2 & 3 again.
4) Start the engine and let it idle. The “_” on the shift indicator will start blinking at 2 second intervals.
The Clutch initialising learning process is complete when “_” “D” and “S” indicators all go off.
STOP the engine
Note: The clutch initialisation learning process is unsuccessful if the “_” starts blinking at 0.5 sec intervals, or goes off and the “D” and “S’ symbols stay on. If so, perform the initialisation learning procedure from Step 2 again.
5) STOP the Engine
6) Restart the Engine, Push the D switch, release and check that the “D” indicator comes on. If it does then you’re good to go!
Bhart89 and Savas like this.
regards
James Mc
post #14 of 17 (permalink) Old 06-16-2017, 12:04 PM
Thanks for posting this👍🏼
Question;
In the following two steps, is the correct procedure to use the key to "STOP" the engine?
My common sense says so, but in case someone is having trouble I thought I'd ask.
5) STOP the Engine
Live to ride
Niterunnr is offline
post #15 of 17 (permalink) Old 06-16-2017, 02:59 PM Thread Starter
Yeah I think so. Then you have to turn the ignition back on to do the rest of the sequence I think
mike5100 is offline
post #16 of 17 (permalink) Old 06-17-2017, 07:43 AM
james.mc's Avatar
Yep! I'd agree, as using the kill switch doesn't give the DCT time to do what it should do, as opposed to what happens on normal shutdown when using the ignition switch/key.
regards
James Mc
post #17 of 17 (permalink) Old Today, 02:16 PM
Thanks everyone for the input on that.. Its always good to now. Cheers
Savas is online now
Human Verification
post count needed mbaur Forum Information & Help 30 05-05-2017 04:42 PM
Why can't I post? alba Forum Information & Help 4 12-27-2016 11:54 AM
Engine Oil Level Check - Why such procedure? Claudio Marinangeli Engine and Technical Discussion 2 09-06-2016 02:35 PM
Running In procedure Hub Architecture Honda CRF1000L Africa Twin General Discussion Forum 8 05-18-2016 04:22 PM
My post was Moderated? MotoMike Forum Information & Help 4 11-28-2015 02:18 PM
