Manual vs DCT Gearing - Honda CRF1000L Africa Twin Forum
post #1 of 14 (permalink) Old 12-30-2015, 06:29 PM Thread Starter
The Manual and DCT bikes have different gearing. I wonder if the DCT has been optimized to be a jack of all trades, master of none type of thing Vs the Manual where sprocket changes are MUCH easier?
Nessuno is offline
post #2 of 14 (permalink) Old 12-31-2015, 01:56 AM
JustPlainBill0's Avatar
Nessuno,
It is not certain (yet) that changing sprockets on a DCT equipped AT will be any more troublesome (by interfering with the DCT computer and getting trouble codes) than on a non DCT bike. Honda would be pretty shortsighted to build a bike that goes against a time honored tradition of changing sprockets and tire sizes on motorcycles - especially dirt bikes. But even so, there's not enough known about how the DCT operates yet to reach a conclusion. We will have to wait to see how it plays out. Perhaps you will be the first to find out.
As for optimizing the DCT to be a Jack of all trades, I don't know whether that's the reason, but they do have slightly different ratios for gears 1 and 2 and the reduction ratios on the NC700 than the NC700 DCT bikes. Maybe this will be helpful :
NC700X/XA-------------NC700XD:
1st 2.812----------------2.666
2nd 1.894----------------1.904
3rd 1.454----------------1.454
4th 1.200----------------1.200
5th 1.033----------------1.033
6th 0.837----------------0.837
Reduction ratios: NC700X/XA 1.731/2.687
Primary/final NC700XD 1.921/2.437
NC700X/XA/XD all use 16T engine sprocket
NC700X/XA - rear wheel sprocket 43T
NC700XD - rear wheel sprocket 39T
JustPlainBill0 is offline
post #3 of 14 (permalink) Old 02-25-2016, 04:56 AM
rob
Has anyone changed sprockets on a manual AT? Ridden a manual 1 an it seems at 100-110kph 6th is kinda useless unless its a long flat highway cuz as soon as u seem to come to small inclines its out of the torque range i found n 5th gear seemed more suited to those speeds
rob is offline
post #4 of 14 (permalink) Old 02-25-2016, 07:24 AM
zoeff50's Avatar
6th gear is meant to be an overdrive, as you said for a long flat highway cuz. Same experience with my current NC700X-DCT bike. At small inclines always use 5th gear. In the DTC S mode (sport) the engine does not go into 6th gear unless you force it by shifting up manually.
It is what it is, an overdrive, and I am happy with it.
rgds, Fred
(CRF1000LAD, CRF Rally Red, Zumo390)
zoeff50 is offline
post #5 of 14 (permalink) Old 02-26-2016, 05:25 AM
rob
I was thinking more along lines of you can shorten the sprockets n sacrifice some top end n still cruose comfy in 6th and then would be a bit better geared for single track
rob is offline
post #6 of 14 (permalink) Old 02-26-2016, 05:15 PM
zoeff50's Avatar
Understand what you are up to, but why?
The AT engine has ample torque. The torque curve is almost flat and you will have more than 90 NM torque from 2200-8000rpm. The engine could easily do with 4 gears. Offroad you will/ can not use 6th and 5th gear I guess. With my NC700X I hardly use the 6th gear, except for easy road cruising. Outside town max 5th gear. The same will apply for the AT I expect.
rgds, Fred
zoeff50 is offline
post #7 of 14 (permalink) Old 02-26-2016, 05:59 PM
rob
Ye i know. I pick mine up today. Didnt do much slow speed on it so once done some slow offroad i can better see if it need sprocket change to do slow offroad tracks
rob is offline
post #8 of 14 (permalink) Old 07-01-2016, 10:36 PM
au contraire! Keep turning the throttle and as the vehicle reaches target rpm and speed, the DCT will shift into 6th.
In sport 3 mode, it will take a very high (illegal) speed for this to happen.
2016 CRF1000LD, '15 NC700XD, '14 CTX700ND
DCTFAN is offline
post #9 of 14 (permalink) Old 07-24-2016, 01:12 AM
You can see theoretical(calculated) rpm and gear ratio detail here.
The CRF1000L is already stored correctly in the database.
Ps. the only reason they changed the gearing ratio on DCT
models is to reduce the 'clunks' when the gears are pre-shifted
into position for the up or down shift.
The final ratio is not much different in both models.
DCTFAN is offline
post #10 of 14 (permalink) Old 07-24-2016, 02:49 AM
Originally Posted by Nessuno View Post
Not topic related but since you posted pic...why are there 3 different models listed?
CRF1000 <--Manual
CRF1000A <--???
CRF1000D <--DCT
Nemesis is offline
Human Verification
DCT Gearing Change? Nessuno Engine and Technical Discussion 13 07-05-2016 03:27 PM
Africa Twin Transmission Options: DCT or Manual? Adventurer Engine and Technical Discussion 33 05-16-2016 02:09 PM
Will More People Choose DCT or Conventional Manual? Paige CRF1000L Prices, Orders and Dealers 6 07-29-2015 04:07 PM
