Starting problems - Page 3 - Honda CRF1000L Africa Twin Forum
 8Likes
post #21 of 59 (permalink) Old 04-23-2016, 08:15 AM Thread Starter
Originally Posted by True Ad Venture View Post
Maybe you misunderstood my post. I was saying a first-run niggle is defective part or a problem that affects a large number of first year bikes. Like the grip heaters and the spokes on the ATs. Don't think failing sensors fall into that category yet.
I wouldn't be a happy camper either if I was getting the run around from Honda. Hope your bike is sorted and it stays problem-free from now.
cheers
fingers crossed 28 out of 30 starts okay so far
Geddy Boy is offline
post #22 of 59 (permalink) Old 04-23-2016, 08:33 AM
Yromulus's Avatar
Which begs the question - what happened on the other 2?!
Yromulus is offline
post #23 of 59 (permalink) Old 04-23-2016, 09:11 AM Thread Starter
nothing it just fired up and stopped in about 2 secs
but I've never had a bike that fired up first time for the total time I've owned it
but something is amiss no doubt
post #24 of 59 (permalink) Old 05-16-2016, 07:52 PM
Mine is doing the exact same thing on every start,hot or cold it doesnt matter.
Will fire up and die inside 2 seconds. Have tried to isolate the problem, thinking switches were faulty but it didnt make any difference.
Im really interested to find out if the sensor replacement fixed the issue you're having.
If so I'll be taking mine back to the dealer for repair too.
This is an Aussie bike #319 build 01/16.
Zoro is offline
post #25 of 59 (permalink) Old 05-16-2016, 09:42 PM
I just disconnected the battery to attempt to reset the ECU, three attempts to start it and stay running proved successful. So, good news up to this point and i will report back if the issue comes back.
Zoro is offline
post #26 of 59 (permalink) Old 05-21-2016, 12:27 PM
African Twin Mofo's Avatar
Anyone have any leak issues? Someone on ADrider in the owners section just posted pics of a leak he has on a standard bike where coolant looks to be seeping out of a press fitting on the right side of the engine.
Don't threaten me with a good time!
African Twin Mofo is offline
post #27 of 59 (permalink) Old 05-26-2016, 07:47 PM
No leaking on mine so far.
Have put about 1000k's since i reset the ecu and no problems starting it or any backfiring issues so pretty happy with it.
Zoro is offline
post #28 of 59 (permalink) Old 05-27-2016, 03:15 AM
xsilvergs's Avatar
My AT has just been returned to me having had cold and hot start problems. See video https://youtu.be/ecdu9_0JFUg.
As the bike had logged no faults they contacted Honda for advice. I'm told that Honda said to replace the tube to the MAP sensor with a longer piece as the original can be kinked.
On the ride back from my dealer the engine appeared to run smoother and it has started every time without use of the throttle.
Thanks to Crescent Honda Southampton
https://www.facebook.com/search/top/...%20southampton
Zoro likes this.
xsilvergs is offline
post #29 of 59 (permalink) Old 05-27-2016, 03:47 AM
xsilvergs's Avatar
As the bike had logged no faults my dealer contacted Honda for advice. I'm told that Honda said to replace the tube to the MAP sensor with a longer piece as the original can be kinked.
https://www.facebook.com/CrescentHonda/
As there appears to be a time limit in which posters can edit their post I have reposted this with the correct Facebook link.
rider_marc likes this.
post #30 of 59 (permalink) Old 05-28-2016, 09:08 AM
Where is this hose located.?
I have looked at the parts breakdown on cyclenation but can't find the MAP sensor anywhere.
Can I see if the hose is kinked without pulling the bike apart?
Zoro is offline
Human Verification
Starting problems Geddy Boy Honda CRF1000L Africa Twin General Discussion Forum 32 04-10-2017 10:21 AM
Replace with
