Optimate connection - Honda CRF1000L Africa Twin Forum
 2Likes
  • 1 Post By xsilvergs
  • 1 Post By williegunn
post #1 of 8 (permalink) Old 05-30-2016, 08:06 AM Thread Starter
xsilvergs's Avatar
Optimate connection
Has anyone fitted a lead for an Optimate charger?
Where did you connect it, direct to the battery, if you connected it to the battery how easy was it as I'm guessing there is little space in the battery compartment for the wiring and the accompanying fuse?
I am considering using the tool box to mount an additional power socket and store the optimate lead.
Thanks in advance.
xsilvergs is offline
post #2 of 8 (permalink) Old 05-30-2016, 10:44 AM
Hi. I connected straight to the battery. Ran the cable up and into the space under the seat. It'll be a bit of a faff to have to remove and refit the toolbox cover when you want to plug in!
welshgar is offline
post #3 of 8 (permalink) Old 05-30-2016, 02:18 PM Thread Starter
xsilvergs's Avatar
I've had a look this afternoon and plan to put two power connectors (DIN type) into the lid of the toolbox, fuses inside, and loop the wires into the bottom of the battery box where the positive lead exits. Should I ever need to get to the battery I just drop the toolbox which can hang on the wires.
I won't need any tools, it's a Honda!
Atlee likes this.
post #4 of 8 (permalink) Old 05-31-2016, 01:17 PM
williegunn's Avatar
On my other bikes, KTMs, charging was really easy, you just plugged the charger into the 12V outlet on the dash and that's what I hoped to do with the AT. I've asked around if this is OK on the AT but no-one can give me a definitive answer, not even my Honda Dealer ! So I have flying lead attached to the battery which accepts my Optimate 4 plug.
M
xsilvergs likes this.
williegunn is online now
post #5 of 8 (permalink) Old 12-11-2016, 11:04 AM
charger
M
my triumphs will charge via the aux socket but My Africa wont.my lead is connected to the battery , I am going to connect a couple of leads to the battery and terminate them in the little tool box to be available for jump starts if its ever needed
Geddy Boy is offline
post #6 of 8 (permalink) Old 12-11-2016, 11:10 AM
doug's Avatar
dealer mechanic fitted mine down right hand side to starter motor connectors
CZ 360, DT175, xt600, fzr600, r1100gs, r1150r, drz400, f800gs, r1200gs, r1200gsLC, CRF1000L
doug is offline
post #7 of 8 (permalink) Old 02-20-2017, 02:29 PM
Picture please.
16rally is online now
post #8 of 8 (permalink) Old 02-21-2017, 08:24 AM
eltel62's Avatar
Direct to battery, that and my Oxford Hot grips are pretty much the most I would like to get directly on the battery, what a pain in the arse to get too and really tight for routing. If you take off the plastic strip below the tank on the left hand side it is easier to route the cable under the frame and have it pop out under the seat. If I started again i would of gone with an Eastern Beaver or something similar, that way I only would have to touch that bloody battery once!
eltel62 is online now
Human Verification
Replace with
