Chain - Honda CRF1000L Africa Twin Forum
post #1 of 7 (permalink) Old 06-05-2018, 03:27 AM Thread Starter
Yetnarsaram's Avatar
Chain
Hello,
I need to replace my chain again 34000miles
I changed my chain at around 17000 ($170)with a OEM
I’m thinking I might try a different brand, does anyone have any suggestions
Min
Yetnarsaram is offline
post #2 of 7 (permalink) Old 06-05-2018, 01:24 PM
mcrag's Avatar
Can't go wrong with EK, RK, or DID.
I used EK x-ring chains on my last two bikes and was very pleased.
mcrag is offline
post #3 of 7 (permalink) Old 06-05-2018, 01:46 PM
I just put a DID XV525 on, seems ok so far.
Dakota Morgan is offline
post #4 of 7 (permalink) Old 12-15-2019, 11:04 PM
For those that are replacing chains. Are you replacing sprockets as well or just the chain. On my dirt bikes I typically replace chain and front and rear sprockets. Also how are you determining chain needs replacement. I have 16,000 miles on my 2016 and chain has only middle way through adjustment range.
upontheridge is offline
post #5 of 7 (permalink) Old 12-16-2019, 12:31 AM
An easy way to check your chain wear is simply to pull up on the chain and pull all the slack out of it and then grab the chain where it wraps around the rear sprocket and pull out away from the sprocket, If you can pull the chain up to the half way point of the depth of the sprocket tooth the chain is worn out. With a chain in good shape you won't be able to lift the chain off the sprocket while holding the chain tight. If the chain is kept in good shape the sprocket wear is negligible. Sprockets wear because the distance increases between the rollers as the chain wears and the chain rides higher up on the teeth of the sprocket and wears out the teeth. That is why really worn sprockets begin to get that saw tooth look. In effect as the chain wears the pitch of the chain changes.
bdalameda is online now
post #6 of 7 (permalink) Old 12-16-2019, 02:34 AM
Fitted the simpler Scottoiler V-system (Vacuum not electronic) on my 2017 AT before first ride in Jan 2018. Now at 39,500 mostly highway miles, the original chain is good for some more miles yet. Not obviously worn, not much of the adjustment range used up.
The Oiler avoids bowing to the chain gods after a long run. Temperature changes require click adjustments. Watch the rear rim; no oil specks, open flow a click. Too many spots, close a little. In 40K miles, I have used less than three bottles of oil from Scotts.
Less bending exercises and cheaper than a new chain.
ghorgan is offline
post #7 of 7 (permalink) Old 12-22-2019, 10:41 PM
DoubleThumper's Avatar
Similar experience, but use a auto-gravity fed system by Tutoro.
Basically, you tweak the volume of flow via a dial, but valve feed is done only by forces opposite to gravity (e.g. a road bump).
Riding is good therapy.
DoubleThumper is online now
Another chain tension question? FarangMoto Engine and Technical Discussion 3 03-08-2017 08:23 AM
Chain Oilers? Juha Parts and Accessories 31 05-30-2016 04:55 PM
tested chain oiler Twister Honda CRF1000L Africa Twin General Discussion Forum 1 05-23-2016 12:49 AM
How Often Do You Lube Your Chain? Dibbs Honda CRF1000L Africa Twin General Discussion Forum 11 05-19-2016 03:22 PM
