How to adjust front suspension? - Honda CRF1000L Africa Twin Forum
 28Likes
post #1 of 44 (permalink) Old 06-24-2018, 08:54 PM Thread Starter
So looking at the manual does not help. I donít have the tool that supposedly came with the bike and I am not sure what I am supposed to me turning. I see the screw on top,then the blue bolt,then the silver one. I have used a wrench to turn the blue but do not hear the click. What am I doing wrong?
Sgtt45 is offline
post #2 of 44 (permalink) Old 06-25-2018, 12:00 AM
The blue bolt is the adjuster for the spring pre-load. Turning clockwise increases the pre-load. There are no "clicks" with the blue bolt, just turns. The full range is about 15 turns (completed 360deg turns of the blue bolt). The standard position is 5 turns (from full soft - full counterclockwise) for the manual transmission and 8.5 turns for the DCT. Same adjustment on both forks.
The inner screw head (at the center of the blue bolt) is to adjust the rebound damping. Turning it clockwise increases the rebound damping. To adjust - turn it fully clockwise (max damping) and then back off (counterclockwise) 2.25 turns for the standard position. The full range adjustment is 3 to 4 turns.
The compression damping adjuster is the screw head at the base of each fork leg (to see this look up from underneath each fork leg directly along the axis of the leg). This screw head does have clicks. Maximum damping is fully clockwise. Standard position is backed of from full by 8 clicks. The total range is approx 12 clicks.
No special tools needed - just a wrench for the blue bolt (19mm if I remember correctly) and a straight head screwdriver for the compression and rebound damping screws.
Hope this helps,
Last edited by TMac99; 06-25-2018 at 12:03 AM. Reason: added comment on tools required
TMac99 is offline
post #3 of 44 (permalink) Old 06-25-2018, 03:26 AM
On my Africa Twin Adventure Sport. When I turn the Blue Spring Preload bolt, the rebound screw turns with it. So be careful to Readjust the rebound screw if you change the Preload.
TMac99 likes this.
aage is offline
post #4 of 44 (permalink) Old 06-25-2018, 07:01 AM Thread Starter
Hope this helps,
Thanks! Now it makes sense!
Sgtt45 is offline
post #5 of 44 (permalink) Old 06-25-2018, 02:30 PM
Root's Avatar
If you are looking for a stiffer front, I have heard mention that several riders have gone with a heavier fork oil in the front. Haven't tried it myself, though.
Root is online now
post #6 of 44 (permalink) Old 06-26-2018, 02:31 AM
aage - You have raised an interesting point about the rebound adjuster turning when the pre load adjuster is turned.
The pre load adjuster and rebound adjuster have pock marks lined up to indicate the factory setting for the rebound adjuster. From that its my understanding is that its the position of the rebound screw relative to the pre load screw that sets the rebound damping.
So if I am correct , when you turn the pre load adjuster the rebound adjuster will turn with it but the relative position of the two will remain the same, hence rebound damping will remain un changed.
Does anyone know for sure
BigKev is offline
post #7 of 44 (permalink) Old 06-26-2018, 04:27 AM
That's what I was thinking too - it needs clarifying
mike5100 is offline
post #8 of 44 (permalink) Old 06-26-2018, 07:45 AM
yes, rebound turns with preload.. use the punch mark for reference on the rebound only.
africano is offline
post #9 of 44 (permalink) Old 06-26-2018, 07:58 AM
eltel62's Avatar
Easy to clarify yourself in about 2 minutes, after adjusting the preload just wind the damping adjuster fully in and back off to the number of clicks you prefer/had set at previously.
ORVdaveVA likes this.
250X7 (first bike 17 years old, T-Boned it in 3 weeks), CB250K4 (needed wheels), CB350K4 (last wheels needed replacing, ran engine without oil after rebuild, DOH!), T500 (didnt handle, didn't care, 2-stroke smoke - EPIC!), 883 Sportster (oh dear, mistake), 1340 Lowrider Covertible (stolen before a year old), Daytona 1200 (heavy, 147BHP mad lump), DR350 (reliable small thumper), CRF1000 (love it)
eltel62 is offline
post #10 of 44 (permalink) Old 07-03-2018, 10:49 PM
knoxswift's Avatar
This is a great post and thread!
knoxswift is offline
Front Suspension Travel 16rally Honda CRF1000L Africa Twin General Discussion Forum 3 02-26-2019 08:25 PM
Unable to adjust display brightness.. 28033 Honda CRF1000L Africa Twin General Discussion Forum 11 02-26-2018 03:51 PM
O E M Spotlight Adjust Drewsieboy Electronics 4 09-03-2017 06:41 AM
AT front suspension MikeCK Wheels, Tires, and Suspension 9 02-23-2017 09:22 PM
