Center stand - Page 2 - Honda CRF1000L Africa Twin Forum
 18Likes
post #11 of 59 (permalink) Old 03-02-2019, 12:57 AM Thread Starter
Africabob's Avatar
I have been trying pulling up with my right hand from the pillion handles on the side of the seat and now I realize this is a huge mistake. I will try pulling from the panniers support way below and leave the "cutting" idea for the last resource!!
Thanks for the advice!!
Africabob is online now
post #12 of 59 (permalink) Old 03-02-2019, 01:01 AM Thread Starter
Africabob's Avatar
[QUOTE=Scorch Dugan;298735]What technique are you using Bob? It can be hard to get the big bike up on the center stand. I find having the front wheel straight in line with the bike and using your right hand on the rear passenger foot
Ggpeg hanger to pull up as your foot presses down on the stand helps a lot. The gradient of the surface you are putting the bike up on is also something you should take into consideration. I wouldn't go cutting the stand, you can't put toothpaste back in the tube!
Great advice, I have been pulling from the wrong places.
I will try from the rear passenger footpeg hanger.
Thanks a Lot!!!
post #13 of 59 (permalink) Old 03-02-2019, 01:08 AM Thread Starter
Africabob's Avatar
Thanks for a great response, I will try these diferent techniques as adviced.
I have not lowered my bike yet, maybe I will in the future.
I don't know if my center stand is longer than the regular one.
I post a picture to show how high the rear tire is from the ground.
Really apreciate your comments and great advice!!
post #14 of 59 (permalink) Old 03-02-2019, 01:32 AM Thread Starter
Africabob's Avatar
Originally Posted by JimInOz View Post
I fitted a Krooztune lowering link, and as part of it, you have to cut out a section of the centre stand.
I've found it a bit easier to get my AT up on the centre stand now.
You just mark a centre line along the legs. Cut out the required length, insert one slug or tube in each leg, align the centre lines and weld it up.
That's the easy part.
Getting it off the bike was a bit harder.
Getting it back on the bike was much harder.
Pictures etc here:
https://krooztune.store/shop/adventu...-lowering-kit/
Interesting!!!
Will keep it in mind if I decide to cut the center stand.
Thank you!!
post #15 of 59 (permalink) Old 03-02-2019, 01:09 PM
Familiarising myself with the new AT I collected yesterday, I really struggled to get it onto the main stand. When I did manage to get it on, the clearance between the rear tyre and ground seemed quite high to me. Reading the posts about technique and trying again today, I realise that I have been trying to lift the bike onto the stand, rather than putting my weight onto the stand lug and pushing it down. The forum advice and practice has been a light bulb moment for me. I now find it easy to put the AT onto the centre stand.
Yesterday I decided never to use the stand and today, thanks to the forum members, it is a piece of cake. If you're struggling, don't give up.
Thanks to all of you who helped me stand and deliver!
RayCollington is offline
post #16 of 59 (permalink) Old 03-02-2019, 07:31 PM
Doug MacPherson's Avatar
make sure that your parking brake is not on when you do this.
deltabi likes this.
Doug MacPherson is offline
post #17 of 59 (permalink) Old 03-02-2019, 08:30 PM
garyh's Avatar
Hey Guys,
Made a quick video showing how easy it is to get my 2018 ATAS on the OEM center stand.
I'm in practice mode with this GoPro I now have, so bear with me. Testing everything out: lighting, sound, staging, editing; the smartphone GoPro app; getting the video from the GoPro to the computer and then to YouTube. Getting some practice time in so Iím prepared for riding videos whenever the VA weather finally decides to cooperateóman, we are looking at more ice/snow over the next two weeks!
But I figured Iíd do it 1) for more video experience and 2) to show what I mean by how easy it is to use the OEM center stand on my ATAS.
In the video I state the bikeís weight as 530 lbs. But my bike in its current state and with the full tank weighs closer to 600 lbs. (533 lbs. stock weight + 40 lbs. of fuel (full tank) + Hepco & Becker Lowers and Handlebar protection + Touratech pannier rack = about 595 lbs.).
Hope this helps some. But the basics on any motorcycle with a center stand is WEIGHT on the center stand foot pad and pulling UP (not back). Itís all technique and once you have it down, itís a cinch from there.
But with my bike, as you can see, she comes up nearly on her own with all my weight on the standís footpad. I weigh 200lbs. So, if you weigh less, some upward pull might be required, but not much. If you weigh more, you can probably get the bike up with absolutely zero upward pull. The stand really does all the work for you when youíre using it right. And this OEM stand on this 2018 ATAS seems perfectly designed and balanced.
Thanks for putting up with my videos. Probably more to come as I work out the kinks. Iím going to re-do the walk-around video I posted a few days ago and have that up in a few days.
Gary
Link to YouTube video: https://youtu.be/BN6qsfKg7wk
dascooter, JimInOz and Bookem like this.
garyh is offline
post #18 of 59 (permalink) Old 03-03-2019, 12:06 AM Thread Starter
Africabob's Avatar
Great video Gary, thanks for sharing, it will help a lot to refine the technique to place the AT up in its center stand.
Now that I can apreciate your rear tire clearence with the floor, I wonder if there are diferent sizes of OEM center stands because, mine, as you can see in the picture I post, my tire clearence is a lot higher!!
post #19 of 59 (permalink) Old 03-03-2019, 04:58 AM
Is it possible that you have a stand for the Adventure Sport and yours is the non Sports bike. I presume the stand on the Adventure Sports is bigger ?
BigKev is offline
post #20 of 59 (permalink) Old 03-03-2019, 05:08 AM
they have different part numbers so this is reasonable.
30th anniversary DCT 'Sport.
Motobiker is offline
Added center stand and stickers Yetnarsaram What Did You Do To Your Africa Twin Today? 10 07-02-2017 01:04 AM
OEM center stand bouncing problem Washryc Honda CRF1000L Africa Twin General Discussion Forum 9 02-22-2017 07:34 AM
Just fitted my SW-Motech Center Stand FarangMoto What Did You Do To Your Africa Twin Today? 2 02-09-2017 01:41 PM
center stand Hemdawg Parts and Accessories 31 01-20-2017 03:25 PM
Africa Twin CRF1000L Center Stand Install WOODZMAN Honda CRF1000L Africa Twin Videos 0 10-19-2016 06:54 PM
