Fuel Starvation - Tank Vacuum - Page 2 - Honda CRF1000L Africa Twin Forum
 5Likes
post #11 of 28 (permalink) Old 05-15-2019, 08:14 AM
I suspect this guy has figured out the problem: https://guglatech.it/en/search?q_mak...+sports&q_sku=
Clearly the ATAS is rather sensitive to fuel quality. I've installed the fuel filter bag and ordered the fuel pump protection as I'm at high risk of poor fuel out here in Uganda. Will let all know whether this makes a difference.
crjbaggy is offline
post #12 of 28 (permalink) Old 05-15-2019, 08:58 AM Thread Starter
Stopped at the shop yesterday, and the good thing is that it is not dying. The bad thing(s) are they have no clue as to why it stopped the behavior, and the engine gets up to 6,000 RPM and it just goes flat like it is starving for fuel. Having it to take on my scheduled trip in 2 weeks is becoming questionable, as I am not wild about it giving up the ghost a couple thousand miles from home.
GL1800A, KLR 650, ATAS, 1972 CT2 Cessna Skylane
Fly low, fly high, but fly!
VFMoore is offline
post #13 of 28 (permalink) Old 05-16-2019, 05:26 PM Thread Starter
Just got an update. Mother Honda is telling the shop that with some L2 models the fuel pump is susceptible to "getting something in them" and it could cause these problems. Total plug, it dies, pressure is off the line, fuel flows starts right up. A partial obstruction could cause the current RPM limit at 6,000 acting as if it is starving for gas. All of those pieces might fit as the tech said that when it quite dying the only thing he had done was slightly move the fuel tank, so perhaps it dislodged whatever it was and went from a full block to a partial block. They are sending a new fuel pump assembly.
VFMoore is offline
post #14 of 28 (permalink) Old 05-16-2019, 10:13 PM
Sounds like a good call, make sure they clean the tank as well. I have seen posts on that.
Torque Request is online now
post #15 of 28 (permalink) Old 05-17-2019, 01:16 AM
Haket's Avatar
I'm getting the same on my ATAS. Feels like fuel starvation when on the throttle. A power reset will return normal operation. It's very annoying.
_________
I like bikes
Haket is offline
post #16 of 28 (permalink) Old 05-17-2019, 03:04 AM
fs996's Avatar
It's good that Honda are trying to sort this out, but equally unless there's a redesigned fuel pump that's less prone to this type of blockage, it could just as easily happen again surely.
fs996 is offline
post #17 of 28 (permalink) Old 05-17-2019, 03:27 AM
The biggest question I have is what is causing this issue which is now seemingly getting more and more widespread across multiple ATAS owners? Mine is bad fuel causing the issue which I've hopefully sorted with additional fuel filters, but others have found bits in their tanks. Regardless the fuel filter in the tank doesn't seem to cope and the fuel pump seems very sensitive causing this surging. VFMoore - did they give any indication on what exactly was 'dislodged'?!
I really hope Honda take notice and come up with a fix for both future and current owners.
MildlyInterested likes this.
crjbaggy is offline
post #18 of 28 (permalink) Old 05-17-2019, 01:52 PM Thread Starter
I hope they identify it when they replace the pump, and that is assuming they have hit on the right problem. To bad it is not as simple as my GL1800 where you run the tank below half, pull the seat, remove the pump and install new, then reinstall the seat. This bloody thing goes in the bottom. Of interest is that they are sending a pump from a 2019 as it is a different manufacturer.
VFMoore is offline
post #19 of 28 (permalink) Old 05-18-2019, 12:19 AM
Ill assume ethanol poisoning until someone shows otherwise.
I never touch the stuff if i can help it, and I usually can.
post #20 of 28 (permalink) Old 05-18-2019, 12:37 AM
black99S's Avatar
Originally Posted by crjbaggy View Post
The biggest question I have is what is causing this issue which is now seemingly getting more and more widespread across multiple ATAS owners? Mine is bad fuel causing the issue which I've hopefully sorted with additional fuel filters, but others have found bits in their tanks. Regardless the fuel filter in the tank doesn't seem to cope and the fuel pump seems very sensitive causing this surging. VFMoore - did they give any indication on what exactly was 'dislodged'?! I really hope Honda take notice and come up with a fix for both future and current owners.
I believe I read over on ADV forum the ATAS tank liner was peeling off and plugging the fuel filter. Can't find the comment / thread despite searching.
black99S is offline
Fuel Starvation ?? Normal?? malcolmbarratt Wheels, Tires, and Suspension 14 10-02-2019 09:28 PM
Squeeling sound from fuel tank? africano Honda CRF1000L Africa Twin General Discussion Forum 8 11-06-2018 02:07 PM
Fuel tank true capacity Sundodger Fuel Economy Discussion 10 08-10-2018 05:27 PM
Help Please! Fuel tank removal. Ray Tuggley Engine and Technical Discussion 2 07-11-2017 10:23 PM
fuel tank removal? davidji Honda CRF1000L Africa Twin General Discussion Forum 6 01-03-2017 06:54 AM
