Gear Shifter Sticks From 3rd up to 4th - New Bike - Honda CRF1000L Africa Twin Forum
post #1 of 6 (permalink) Old 05-16-2019, 07:02 AM Thread Starter
I just purchased my New 2018 Adventure Sports. The bike is great except when accelerating quickly, sometimes I have a problem shifting from 3rd to 4th. I had a similar issue with my CBR250R going from 2nd to 3rd. The way it feels is I pull up the gear shifter and it does not click/ clunk into the next gear, I have to let out the clutch while remaining in the same gear which is jerky, then I try again and it clicks right into place like it should. Whenever I have this issue, it always shifts up to 4th on the second try. I have never tried double tapping it while the clutch is still pulled in, but this might work as well.
I know oil has an affect on how your shift works, but this bike had 0 miles when I bought it and I've only put about 50 miles on it when this issue started to occur. Is this a symptom of the oil the dealer used for the break-in period, or maybe the oil contamination from the first 50 miles? Anyone else have any idea or had this issue too? Thanks.
TrevorNoah is offline
post #2 of 6 (permalink) Old 05-16-2019, 08:38 AM
Rear chain tension.
I found that the standard 45mm slack is too tight. backing off to 50mm improves gear changes for me.
2016 AT manual. 2005 TA. 1949 Scott 600.
zarafah is online now
post #3 of 6 (permalink) Old 05-16-2019, 11:53 AM
knoxswift's Avatar
X2 on Rear chain tension.
knoxswift is offline
post #4 of 6 (permalink) Old 05-16-2019, 12:24 PM
garyh's Avatar
My bike, from the dealer, had too much slack at the chain. And became even more slack over the first month or so. I like mine at about 50mm too, though. Definitely the sweet spot.
Gary
garyh is online now
post #5 of 6 (permalink) Old 05-16-2019, 03:03 PM
Another thing to think about is your shifter position. I had the problem when I changed boots and found that the thicker toe was holding the shift lever up to the extent that it was not resetting to take the next step.
GL1800A, KLR 650, ATAS, Cessna Skylane
Fly low, fly high, but fly!
VFMoore is offline
post #6 of 6 (permalink) Old 05-16-2019, 05:36 PM
garyh's Avatar
Good point! It took me a few tweaks to get my shifting as smooth as I felt it should be on my ATAS: first was to fix the chain slack - put it at 48mm with about 250 miles on the bike and it self-adjusted over the next 250-500 miles or so to about 50mm (worked itself in), where I try to keep it now. It stays there pretty well now with some miles on the bike/chain (but allow for some slackening of the new chain the first 500 miles or more). And second was adjusting my shifter - took it off and moved it one spline (that was about a full inch of difference at the shifter knob where I was then able to fine tune with the adjuster rod) and it works like a charm for me now. (I have big feet).
Good luck, Gary
garyh is online now
Gear Shifter Sticks From 3rd up to 4th - New Bike Soviet Tiger Honda CRF1000L Africa Twin General Discussion Forum 3 11-05-2018 05:12 PM
Bike shops near London with adventure gear? encoad Honda CRF1000L Africa Twin General Discussion Forum 2 01-17-2018 02:45 PM
3rd day of ownership RobertKLR Honda CRF1000L Africa Twin Photos 4 10-01-2017 01:59 PM
Shifter Adjustment Divenride Wheels, Tires, and Suspension 4 07-18-2016 01:01 PM
