Throttle Lock Thoughts.. - Page 3 - Honda CRF1000L Africa Twin Forum
 3Likes
post #21 of 25 (permalink) Old 07-28-2017, 09:42 PM
Originally Posted by Ridenfun View Post
Can someone confirm for me the method to remove the stock end cap to remove the stock handguard out of the way. Is it standard thread direction, ie left to loosen, right to tighten. Mine seems to be frozen solid in place even with the correct sized hex into it. Any tricks/suggestions welcome
They are standard threads with red loctite on the threads.
It takes a bit of force to break them loose, then they unscrew easily.
They have a bit of pressure on them from the internal bar weights. I drilled and tapped mine so I could keep the bar end weights with Acerbis guards.
doctord23 is offline
post #22 of 25 (permalink) Old 07-28-2017, 11:04 PM
Doc, thanks for the quick response on this. I can't believe how tight these things are on, at least on my bike, so was concerned I was missing something unique.
Ridenfun is offline
post #23 of 25 (permalink) Old 07-29-2017, 01:55 AM
Yes, left to loosen. Mine came off easily.
Davy F is offline
post #24 of 25 (permalink) Old 07-29-2017, 05:17 PM
Interesting. I did finally get my right one off, but with MAJOR force, then it finally broke free and came off easily. I mention this for others in future, since it appears some are locktited on much more than others. Mine had about 3/8 to 1/2 inches of Loctite, at the inner mostl part of the thread.
Ridenfun is offline
post #25 of 25 (permalink) Old 07-29-2017, 05:55 PM
I just used two yellow Catapillar O rings, one between the throttle flange and housing and the other which rolls on and off of the bar end weight.
racer is offline
Helmet Lock wytco0 Honda CRF1000L Africa Twin General Discussion Forum 16 11-26-2016 07:08 AM
Should I buy? Now having second thoughts! Striker Honda CRF1000L Africa Twin General Discussion Forum 41 10-30-2016 07:50 PM
U-lock Dimensions Yromulus Parts and Accessories 11 06-02-2016 02:53 AM
Thoughts on the Dash? Paige Electronics 2 07-11-2015 11:01 AM
