Valve adjustment - Page 2 - Honda CRF1000L Africa Twin Forum
 4Likes
post #11 of 21 (permalink) Old 11-01-2019, 10:28 AM
I have not herd of anyone needing to shim the exhausts, the intakes are adjusted with w screw/lock nut. (I haven't herd of any intakes that REALLY need adjusting either).
Torque Request is offline
post #12 of 21 (permalink) Old 11-01-2019, 10:45 AM
Talking to my honda dealer the other day about this, I asked when to have them checked,they replied 30,000miles is ok but we havent had to make many adjustments on the vast majority of bikes we have inspected....
harleywilma is offline
post #13 of 21 (permalink) Old 11-01-2019, 11:02 AM
It is the other way round, the intake ones are adjusted by changing shims (and nobody has ever needed any yet) and the exhaust ones are adjusted with screw/lock nut.
XLGeorge is online now
post #14 of 21 (permalink) Old 11-08-2019, 03:07 AM
Iíve started to strip down my bike for its first valve check. Never have I had a bike that so much kit has to be removed for a service, itís virtually giving me nightmares !!!! Awkward just doesnít accurately describe this job.
Davy F is offline
post #15 of 21 (permalink) Old 11-08-2019, 08:13 PM
Getting close to 60k on my 2016 manual, to check or not check the valves. The bike runs perfect, starts perfect, gas mileage the same as the day I bought it. Iím thinking,just going to keep on riding & maybe check at 100k. 💯👀😎
Simmons1 likes this.
Desert rider is offline
post #16 of 21 (permalink) Old 11-09-2019, 05:33 AM
Originally Posted by Davy F View Post
I’ve started to strip down my bike for its first valve check. Never have I had a bike that so much kit has to be removed for a service, it’s virtually giving me nightmares !!!! Awkward just doesn’t accurately describe this job.
I have stripped down my VFR VTEC in the past to get to the valves - and this is considered a complex bike due to the V4 arrangement - but I can confirm that the CRF is even more complex to get to them. In my case, I decided to leave the dismantling/assembly job to a mechanic/friend with the agreement that I would check the valves, which I did.
Originally Posted by Desert rider View Post
Getting close to 60k on my 2016 manual, to check or not check the valves. The bike runs perfect, starts perfect, gas mileage the same as the day I bought it. I’m thinking,just going to keep on riding & maybe check at 100k. ������
I haven't found much wrong with mine at 46K km, apart from an exhaust one that was slightly open at 0.27 with limit 0.25. But maybe 100K km is too long an interval for the exhaust ones that use screw/locknut - just in case any one of them closes too much (the intake ones that are shim-based will be surely within the limits).
post #17 of 21 (permalink) Old 11-12-2019, 03:22 AM
Progress so far. Down as far as throttle bodies and coil pack removed....radiators will come off next as thereís very limited access otherwise.
ID:	51073   Click image for larger version
ID:	51075   Click image for larger version
Davy F is offline
post #18 of 21 (permalink) Old 11-13-2019, 10:24 AM
Greg the Pole's Avatar
Follow the procedure in the book.
yes there's a bit of stuff to take off. Clean as you go.
Exhaust is screw and nut. My exhausts were on tight side, but in spec, so I moved it to the loose side, super easy adjustment.
My intakes were down middle of spec at 27k km.
For those on the fence, roll the dice. I may skip my next one, as I know where I'm at after break in. But it's there a reason for the interval check.
The spark plugs are due at 48k..so I'll scratch the above comment, and go in and check the valves anyways. The two inner spark plugs are impossible to get to with the tray in the way.
An old Polish saying: Nie muj cyrk, nie moje malpy! Not my circus, not my monkeys
Ramblings of a muppet: https://thetenerist.wordpress.com/
Greg the Pole is offline
post #19 of 21 (permalink) Old 11-18-2019, 01:39 PM
All done and dusted...no adjustments needed and my chum reckons leave it until 40/50k miles before doing them again.
Now for the rebuild....
ID:	51175   Click image for larger version
Davy F is offline
post #20 of 21 (permalink) Old 12-09-2019, 04:28 AM
Itís alive !!! And thank fek Iíll not be doing that again until 48k....
Speedo007 likes this.
Davy F is offline
Valve train noise VicAT Engine and Technical Discussion 16 04-25-2019 11:00 PM
Rear Brake pedal adjustment 6986 Engine and Technical Discussion 6 11-18-2018 01:07 PM
Spot light Adjustment Geddy Boy Electronics 7 11-15-2018 04:26 PM
Shifter Adjustment Divenride Wheels, Tires, and Suspension 4 07-18-2016 02:01 PM
