Valve adjustment - Honda CRF1000L Africa Twin Forum
 4Likes
post #1 of 21 (permalink) Old 01-20-2017, 01:47 PM Thread Starter
Question Valve adjustment
Im adjusting the valves on an Africa Twin does anyone know if the spec for exhaust valve clearance is measured between the valve and adjuster or between the cam and rocker arm.
ATDCT is offline
post #2 of 21 (permalink) Old 01-20-2017, 05:18 PM
Service manual page 3-10, says feeler gauge between the rocker arm roller and cam lobe for exhaust valve.
XR650RRider is offline
post #3 of 21 (permalink) Old 01-21-2017, 10:58 AM Thread Starter
Thanks for the info thats a big help. If you have the manual can u confirm the clearance specs? I have
Intake 0.16 + or - 0.02mm
Exhaust 0.23 + or - 0.02mm
Are these correct?
ATDCT is offline
post #4 of 21 (permalink) Old 01-21-2017, 02:21 PM
Intake 0.16 +/- 0.03 mm (0.006 +/- 0.001 in)
Exhaust 0.23 +/- 0.02 mm (0.009 +/- 0.001 in)
post #5 of 21 (permalink) Old 02-05-2017, 03:50 AM
hi everyone,
i have traveled on the my africa 30 000km.
what is the procedure when adjustment? it is necessary to dismantle the engine from the frame?
thank you very mach
madracik,Slovakia is offline
post #6 of 21 (permalink) Old 02-07-2017, 10:18 AM
Juha's Avatar
Originally Posted by madracik,Slovakia View Post
hi everyone,
thank you very mach
https://www.africatwinforum.com/forum...op-manual.html
Juha is offline
post #7 of 21 (permalink) Old 02-07-2017, 01:15 PM
thank you wery much. it's what i needed. great
Juha likes this.
post #8 of 21 (permalink) Old 02-14-2017, 09:46 AM
Thanks!
warrimurf is offline
post #9 of 21 (permalink) Old 06-05-2018, 12:31 PM
Ziggy's Avatar
Valve Shim Size
Any one know what size valve shims the ATwin takes. Hoping they are standard 9.48mm size...
Ziggy is offline
post #10 of 21 (permalink) Old 10-30-2019, 09:40 PM
I'm trying to find definitive size information as well...I'm 99% sure the shims for AT are 9.48mm same as the ones for several other bikes including their 450 motocrosser. My Suzuki DR-Z400S used that same size, so I already have a full set. I'd sure like to see it in an official Honda document, but I haven't seen that yet.
JohnBeng is offline
Valve train noise VicAT Engine and Technical Discussion 16 04-25-2019 11:00 PM
Rear Brake pedal adjustment 6986 Engine and Technical Discussion 6 11-18-2018 01:07 PM
Spot light Adjustment Geddy Boy Electronics 7 11-15-2018 04:26 PM
Shifter Adjustment Divenride Wheels, Tires, and Suspension 4 07-18-2016 02:01 PM
