Chain maintanence - Page 2 - Honda CRF1000L Africa Twin Forum
 4Likes
post #11 of 26 (permalink) Old 01-18-2018, 07:26 AM
Chain maintenance
Its easier to do adjustment on the centre stand then check tension is OK on side stand. You quickly get a feel for how the tension varies between centre stand and side stand. As regards chain lub and rusty side plates:
The main bits that are loaded and wear on a chain are lubricated and sealed for life with O rings. When you lub the chain you are:
1. Stopping the outer surfaces rusting
2. keeping the O rings lubricated so that they do not dry out and break up /wear
3. keeping the surfaces that come into contact lubricated, ie sprocket and chain.
There are many lubricants, wax types are popular but I prefer those that are more penetrating and less gungey. I use XCP. Lubing without cleaning is fine if you are away from home but long term lubing without cleaning is just building up a big mess on the chain.
BigKev is offline
post #12 of 26 (permalink) Old 01-19-2018, 06:34 PM
24,000 miles chain still looks new
Drum Dog likes this.
Desert rider is offline
post #13 of 26 (permalink) Old 01-19-2018, 06:59 PM
WTF
Originally Posted by Arguz View Post
Have anyone else used this laser tool?
https://www.profi-products.de/en/pro...um-housing?c=6
Yes, but whether it is worth buying is debatable.
WTF is offline
post #14 of 26 (permalink) Old 01-19-2018, 09:08 PM
RobertKLR's Avatar
Originally Posted by ablock View Post
So while I keep the chain well lubricated and see no issues with excessive slack at 3,700 miles, the outside plates of each link are quite rusty. Is this normal?
My KLR's chain exhibits a rustiness often on the chain outside side plates and it has never been an issue. I just lube it and wipe the chain down afterwards. I have yet to see any rust on my AT chain (at 3,200 miles) though. But it may not be an issue either because the AT comes with a hefty chain and a rusty appearance on the side plates won't hurt anything. By the way has the bike been ridden in the rain? Road splash is loaded with crap that can cause a rusty appearance. Lube it, wipe it down and see if it goes away.
RobertKLR is offline
post #15 of 26 (permalink) Old 01-20-2018, 03:51 AM
Yeah, I park outside not always with a cover and it's been raining lately. I'll lube this weekend and see if the chain cleaning brush and a light pass with a rust eraser helps at all. Thanks.
ablock is offline
post #16 of 26 (permalink) Old 01-21-2018, 07:58 AM
I agree that rust on the outside of the link plates is just a cosmetic issue but if the chain shows rust its a warning that the surfaces that come into contact may need some lub. However I have found that after washing the bike the water left on the chain leaves rust spots on the link plates even though the chain may have recently been lubed.
BigKev is offline
post #17 of 26 (permalink) Old 01-21-2018, 02:07 PM
Yeah Kev - I have found the same. Honda say you have to rinse the bike in clean water after a ride (in winter), and inevitably that puts water on the well lubed chain. Despite me using a Sidekick airblaster to dry the chain throughly, the rust still appears.
mike5100 is online now
post #18 of 26 (permalink) Old 01-21-2018, 07:53 PM
R.M
Same happens to me!
R.M is offline
post #19 of 26 (permalink) Old 01-22-2018, 05:35 AM
eltel62's Avatar
They can easily get that way after just a few days after being in the wet, even after a wash. It is only a light surface coating and nothing to get worried about. When lubing your chain you are only really lubrication the O-Ring as the lubrication grease is sealed in by them and it is those you are keeping in good order. If you wash your bike (or go out in the wet) just wipe the chain with a rag to clear off any excess water and lube your chain then. After lubing your chain you might wipe it down with a rag to spread a little lube all over the chain to prevent the rust.
eltel62 is offline
post #20 of 26 (permalink) Old 01-27-2018, 12:13 PM
Originally Posted by Cuchulainn View Post
Do you do your own maintenance? Otherwise I would be surprised if the dealership isn't checking it. Mine checks and adjusts it anytime I have the bike in.
Its a bit mixed. I do my own oil changes, but anything beyond oil I have the dealer do. I am sure they are checking it when I go in. I just wanted to be dramatic! hahaha
Cuchulainn likes this.
Dakota Morgan is offline
Tutoro chain oiler Stromcat Honda CRF1000L Africa Twin General Discussion Forum 20 05-03-2019 06:55 PM
Another chain tension question? FarangMoto Engine and Technical Discussion 3 03-08-2017 08:23 AM
Chain Oilers? Juha Parts and Accessories 31 05-30-2016 04:55 PM
tested chain oiler Twister Honda CRF1000L Africa Twin General Discussion Forum 1 05-23-2016 12:49 AM
How Often Do You Lube Your Chain? Dibbs Honda CRF1000L Africa Twin General Discussion Forum 11 05-19-2016 03:22 PM
