Gear Position Indicator flashing - Honda CRF1000L Africa Twin Forum
 2Likes
  • 1 Post By Sundodger
  • 1 Post By africano
Old 02-19-2018, 01:51 PM Thread Starter
lee711's Avatar
I have read through the owners handbook and searched the forum and can't seem to get any info on this matter, can anyone advise as to whether the gear indicator on the DCT model is supposed to flash. I have been through all the drive mode settings and nothing changes this, it flashes in all gear positions when stationary and moving. I only picked the bike up on saturday and i'm just getting used to it and wondered if this was normal or something more sinister. I understand the issues around this "-" appearing on the screen but not when gear numbers are flashing. Thanks in advance.
lee711 is offline
Old 02-19-2018, 03:20 PM
I've never seen it on my DCT, I'd be on the phone to my dealer. Hopefully it will just require a 'reset' of the electronics. Seems to be the common fix for most gremlins these days IMHO.
lee711 likes this.
Sundodger is offline
Old 02-20-2018, 09:10 AM
Had this problem a few times. I cut the contact and it is gone. Asked the dealer but never had an answer.
I don't now why it appears. My bike went to the dealer, 3 weeks ago, for 48000 Km maintenance. I started this Sunday and had it again.
Stop the engine restart and no flashing. May some of the dealers have an answer but my dealer don't now what it is.
Bartho is offline
Old 02-20-2018, 11:45 AM Thread Starter
lee711's Avatar
Thanks for your input @Bartho
lee711 is offline
Old 03-21-2018, 02:59 PM Thread Starter
lee711's Avatar
I may have found the root of the issue. I plugged the SCS lead into the DLC (data link connector) turned on the ignition and got an Flashing ABS DTC, 1 long and 2 short which equates to a front wheel speed sensor malfunction.
- Wheel speed sensor, pulse ring or related wires.
- Electromagnetic interference
I did a visual check and all seems fine, so I erased the DTC code and will check tomorrow after my work commute to see if it reappears ( it may be a stored old code that hadn't been cleared ) Next step will be a call to the dealers. On a side note the ABS lights perform as they should upon start up and running with wheels turning so i know there is no issue of the ABS not functioning.
lee711 is offline
Old 03-22-2018, 02:27 AM
I have had a abs light flash on start up on my VFR1200 DCT when the battery was going down. This was common on these bikes.. Replaced the battery, never a problem again. This might not be the problem at all but it could be related.. When you crank the bike and the voltage dips too low the electronics could act up.. check the voltage when you start the bike..
lee711 likes this.
africano is offline
Old 03-22-2018, 03:27 AM
This could be the reason(low battery) . I will keep an eye on it next time. Had it last week and bike was inactive for two weeks.
Bartho is offline
Old 04-21-2018, 03:19 AM Thread Starter
lee711's Avatar
I have now sorted the problem out, I got it plugged in at the dealers and the issue was in the speed sensor circuit, this in turn fired up a speed sensor fault code. After I cleared the code the fault in the speed sensor circuit remained which was the reason for the gear indicator to remain flashing. The dealers have ordered me a new speed sensor wiring kit and will replace the speed sensor as well whilst they are at it, great service from the guys at Wigan Honda UK, all work carried out under warranty and a courtesy bike while mine is in.
lee711 is offline
Potentially (probably) daft question regarding lower seat position Yromulus Appearance & Body 34 03-25-2019 03:07 PM
Ugly gap with seat in low position pjm Appearance & Body 10 01-17-2019 04:33 AM
is it just me or is the seat difficult to fit in the low position mike5100 Appearance & Body 11 04-25-2017 02:05 PM
indicator not cancelling. CliveW Electronics 2 03-06-2017 01:03 PM
Barkbusters led light indicator install NetJack Electronics 0 02-21-2017 11:13 AM
