Cost of valve check/adjustment - Page 6 - Honda CRF1000L Africa Twin Forum
 15Likes
post #51 of 55 (permalink) Old 07-18-2019, 06:22 PM
I just don't get why Honda did this to people. An adventure bike needs to be serviceable. An air filter needs to be a 10 minute job.
As for valves I'm now 65 and run my bikes easy these days. Just touring/camping and easy cruising. No more hi-RPM stuff like when I was in my 20s.
I can easily run a bike to 80km (50,000 miles) and not worry about valve shim clearance. Last time I checked a set of valves at 30,000 miles the were still fine. So I no longer even think about them.
I was giving the AT a serious look but from all I have seen/read/heard, I may take it off the list. I think I will wait till I can see the Yamaha T700. I like the size, fit, more power then I need but I have got to have a bike that is easy to service.
lhedrick is offline
post #52 of 55 (permalink) Old 07-18-2019, 10:17 PM
Im_Too_Tired's Avatar
Originally Posted by jamnut View Post
... Labor was 5 hours billed at $212.50 with parts being billed at $249.00, totaling $461.00.
Nice deal other than having to wait 28 days. Here in Florida the rate is $130/hr
Im_Too_Tired is online now
post #53 of 55 (permalink) Old 07-22-2019, 02:46 AM
Originally Posted by knoxswift View Post
So on the invoices from dealers, I'm curious. when they did the job is New Coolant charged?
New Spark Plugs charged? or do they just put back the old?
These are things that don't make sense. 100K coolant but needs to be drained to do valve check?
Check Plugs, but you're in there so might as well just change them out?
So just curious what people's dealer invoices actually read for this $1000+?
The plugs get a check at 24,000km make sure the gap is not over 1mm (first valve check) replaced at the next one 48,000km (second valve check)
Coolant is NOT drained to do valve check. Coolant is changed at time, 3 years you don't need to do much other than undo one drain screw on side case then refill radiators for that, does not need to happen at valve check you can do that without disconnecting radiators. On the invoice there will typically be oil and filter $75(that's a kit in a box here in AU including the washers) , air filters $90 labour 8 hours and whatever else they may have done? So depending on what labour rate they quote that's a big chunk of the inv
SkipD is offline
post #54 of 55 (permalink) Old 08-01-2019, 08:09 AM
I had the valves checked at 17k miles. Just one of the exhaust valves needed adjustment all the others were within tolerances. While they were checking the valves I had them replace the air filters as well. My total cost including the air filters was $567. I was billed for 7.5 hrs labor.
sjhoff67 is offline
post #55 of 55 (permalink) Old 08-09-2019, 04:39 PM
Hey XLGeorge did the 43 sprocket make much difference for off-road riding & much difference on your gas mileage ❓❓
Desert rider is offline
Removing the Air Box for Valve check question Ziggy Engine and Technical Discussion 8 03-19-2019 10:08 AM
Headlight Protection vs Headlight Cost (US$1087) TMac99 Appearance & Body 35 11-11-2018 08:30 PM
Valve adjustment tutorial I SHIFT Engine and Technical Discussion 3 10-30-2018 11:54 AM
Valve adjustment ATDCT Engine and Technical Discussion 8 06-05-2018 11:31 AM
Import cost to UK from US Q-Ball Honda CRF1000L Africa Twin General Discussion Forum 0 02-26-2017 12:07 PM
