Dipstick troubles. - Page 3 - Honda CRF1000L Africa Twin Forum
 7Likes
post #21 of 25 (permalink) Old 11-15-2018, 11:12 PM
garyh's Avatar
Originally Posted by dascooter View Post
Manual is a bit confusing. Below is copied form the manual. Says when checking oil level to place bike in an upright position. Is that on the side stand or center stand?
Dascooter, I assume it means up-and-down, not on the stand. I don't have a center stand (or a paddock stand yet) so I put the side stand on a flat block so it's more vertical but still reasonably safe. Then it just takes a little push to get it straight up-and-down while I check the oil. I also position the bike so the right side is near the wall, just in case. But like most bikes, it's pretty easy to balance it with little effort.
dascooter likes this.
garyh is online now
post #22 of 25 (permalink) Old 11-16-2018, 09:36 AM
dascooter's Avatar
Great idea. I do not have a center stand yet either because of the recall. Block of wood a great idea.
dascooter is online now
post #23 of 25 (permalink) Old 11-16-2018, 10:09 AM
jamnut's Avatar
Originally Posted by Tigermike View Post
First time posting here so bear with me. I'm putting the AT down for the winter here in Minnesota for the first time (bought used in August), it slapped us pretty hard already. I warm up my garage with the bike in there all day. I drain the oil cold and replace the filter. I let it drip over supper. I come back and tighten up the drain plug. The manual says 4.1 liters with a filter change so I put in 3.5 qts and push the bike outside and run it for 10 minutes. I bring it inside and let it sit for 5 minutes and unscrew the dipstick and reinsert it to the threads. The thing reads like an inch over the top line. ????? Great, bad info in the manual. I pull off the skid plate and drain about a half a quart out, reinsert the stick again and it is over an inch still. I drain more out and again checking it it's an inch over. I'm pissed now so I completely drain it, that'll show it who's boss. Much to my dismay it still reads as too full. I tried putting it in at various angles and it still reads the same. I have no idea what could be causing this. I put the oil I drained out back in and left it. There should be enough oil in there to operate it but as far as getting a proper oil level I have no idea how I'm going to do that. Anybody else have this problem?
I can't believe everyone missed it.... right there in the first line! "putting her down for the winter" Heated grips and longjohn's for those sunny winter afternoons Tigermike...
jamnut is offline
post #24 of 25 (permalink) Old 11-16-2018, 09:33 PM
Un-screw all bolts before you drain & oil filter, this is the best way to remove oil from engine & donít forget to put oil back in the engine. PS make sure you buy slippery oil , I have read a lot of research on oil & the slippery kind is highly recommended. 👍🤡🤡🤡🤡
Desert rider is offline
post #25 of 25 (permalink) Old 11-17-2018, 09:11 AM
Jamnut, you don't say where you live, but I live a couple of hundred miles south of Minnesota, and after there starts to be frozen water on the ground, I'm done, too. Even thawed frozen water (with salt in it) is too much trouble. Besides, people in cars are fools on ice. Fools, I tell you!
jamnut likes this.
Shadowjack is online now
Someone Give Me a Hand with my Dipstick WurfmesserPaul Engine and Technical Discussion 2 06-29-2017 12:30 AM
