Engine Braking - Page 2 - Honda CRF1000L Africa Twin Forum
 6Likes
post #11 of 16 (permalink) Old 03-09-2019, 03:05 AM
black99S's Avatar
Originally Posted by mike5100 View Post
Depends whether you want comfort or speed. If you like driving hard then having high engine braking is probably a good idea, but for me the constant slamming backwards and forwards is just tiring. So surely it's better for us to be able to choose how much engine braking we want?
That's what the throttle is for - feather it for light engine braking, close it for more. I do understand people like the ability to tune a bike to their needs and throttle by wire allows for a lot of electronic wizardry. I just wish Honda would spend a few bucks on the suspension instead of electronic stuff.
ORVdaveVA likes this.
black99S is online now
post #12 of 16 (permalink) Old 03-09-2019, 06:17 AM
I’ve heard of feathering the clutch but never before heard of feathering the throttle. It’s so sensitive at the bottom end, I doubt I’d be able to control engine braking via the throttle. And wow - it just shows how difficult it is for Honda to cater to all tastes because the reason I’m buying another Africa Twin is mainly because I think the suspension is just brilliant.
MPNM likes this.
mike5100 is online now
post #13 of 16 (permalink) Old 03-09-2019, 03:59 PM Thread Starter
I wasn't questioning the benefit of engine braking, I only asked out of curiosity as to what was actually going on in the engine. As we know, trucks fitted with the old type exhaust brakes worked by the compression of the exhaust being released to the inlet on valve overlap at the end of the exhaust stroke. The compression stroke had no effect as after TDC the resultant cylinder pressure acts pushing the piston down. Other variants (ie Jacobs brakes etc) change the valve timing, effectively turning the engine into compressor. If the AT only works by closing the inlet butterfly, I could be wrong, but if this is the case, it seems little more than a token gesture.
I am sure there is a Honda technician out there that will answer my curiosity.
RayCollington is online now
post #14 of 16 (permalink) Old 03-10-2019, 09:17 AM
I was under the impression that exhaust brakes on trucks are only fitted to those with diesel engines, which are not throttled (no carburetor blades, no intake vacuum). The closure of the exhaust path increases the backpressure, which has the same effect as closing the intake blades. But I could be mistaken.
The Honda variable engine braking feature can only work by keeping the throttle blades open a small amount, which would reduce the braking effect. It would appear that this may be beneficial in repeated very low-speed, small-throttle-movement circumstances, to smooth out the jerkiness.
RayCollington likes this.
Shadowjack is online now
post #15 of 16 (permalink) Old 03-10-2019, 02:07 PM
Presumably if this is what Honda are doing they could only open the butterflies when the throttle was fully closed (otherwise they knock their Euro emissions figures for 6 even though there would be modes where they would still be compliant)?
post #16 of 16 (permalink) Old 03-11-2019, 08:45 AM
I imagine the fuel is cut off.
adjusting the engine braking - does it work? mike5100 Engine and Technical Discussion 29 11-04-2018 01:10 AM
Engine braking - Slipper clutch? JimInOz Engine and Technical Discussion 3 08-30-2018 06:42 PM
2018 ATAS Engine Braking (EB) settings garyh Engine and Technical Discussion 0 07-19-2018 01:59 PM
variable engine braking mike5100 Honda CRF1000L Africa Twin General Discussion Forum 4 06-14-2018 05:16 PM
variable engine braking BigKev Engine and Technical Discussion 5 03-08-2018 01:26 AM
