What reset procedure is this? - Honda CRF1000L Africa Twin Forum
post #1 of 12 (permalink) Old 03-27-2019, 06:31 PM Thread Starter
Is this procedure the solution to cold starts?
I recall regarding this procedure sometime last year but can't find the thread. Tried searching in the service manual via "find" but nothing.
I know the youtuber is trying to use this reset procedure as a fix for the cold start but I doubt that's the solution. I could be wrong though.
Is this truly the fix to cold starts with our ATs? I thought it was the start switch itself. I read a thread saying that's what it was and that Honda will replace it. But if you're out of the warranty period but have an extended warranty via 3rd party will they still cover?
Nemesis is offline
post #2 of 12 (permalink) Old 03-27-2019, 06:44 PM Thread Starter
Btw, what is the lit up red symbol on the gauge cluster? I dont see it on my manual AT nor in the handbook displaying all the symbols on cluster.
Nemesis is offline
post #3 of 12 (permalink) Old 03-27-2019, 08:40 PM
HerrDeacon's Avatar
I found a thread on this site about the procedure but there must be some rule in place to prevent new users from posting links so I can't let you know where to find it
Here is the text from that post:
From user Onetime39
Hey all, I took my 2016 manual AT in to the dealer for the hard starting issue. 1700 miles and was getting harder to start 40-55F weather. Throttle Position Sensor was the problem. The dealer told me this is what Honda told them to do. The fix is simple, turn the key on and wait for the
screen to display the CRF symbol and turn ignition off. Hold down the starter button and throttle open all the way open for 5 seconds and this resets the TPS. This has fixed my hard starting issue and no problems since then.
Also, found another YouTube video but can't post the link, ha ha. Search for video BjjygK2KeG8
HerrDeacon is offline
post #4 of 12 (permalink) Old 03-27-2019, 10:09 PM Thread Starter
Thank you.
Hmm...first time hearing about this. Thank you. I'll give it a go tomorrow and see if that fixes it.
As for the oil in the catch tube...yeah, I read about that but I think that's the cause because I have zero oil in the tube and my bike still does it.
Nemesis is offline
post #5 of 12 (permalink) Old 03-28-2019, 11:15 AM
All I've ever done to resolve the cold start issue with my bike (DCT but shouldn't matter) is to turn on the ignition, wait for the start sequence to finish and the display settle, open and close the throttle fully and then start the bike. Been doing this for a year now and it starts and runs first time every time and doesn't hiccup and stall after a second or so as it did previously.
Sundodger is offline
post #6 of 12 (permalink) Old 03-28-2019, 02:18 PM Thread Starter
I just tried your method (sorta) and it worked. I couldn't remember whether to open/close the throttle before or after the display was settled. So I just open/closed the throttle before the display, and it started right up.
Weird.
Just to double check whether it was a fluke or not, I'll attempt another restart later in the afternoon.
Nemesis is offline
post #7 of 12 (permalink) Old 03-28-2019, 11:12 PM Thread Starter
Okay...so two things regarding:
From user Onetime39
1) I don't think the US models have the HISS system/indicator in the gauge cluster so that procedure didn't work for me
2) however, I attempted it anyway and the bike didn't fire up in its first attempt
3) I attempted Sundodger's suggestion and same as above
4) I tried my procedure (gave it a couple turns before display) then it fired up on both attempts. Not completely convinced my method works because Sundodger's method may have played a part. To be sure, I'll try my method tomorrow morning.
Nemesis is offline
post #8 of 12 (permalink) Old 03-29-2019, 03:40 PM Thread Starter
Well, it's confirmed: a few twist of the throttle before display startup and the engine started on its first attempt.
Don't know why but I'm still not convinced this works. LOL I'll give it another go later this afternoon and tomorrow morning.
Nemesis is offline
post #9 of 12 (permalink) Old 03-29-2019, 09:18 PM
Stevo17's Avatar
I am pretty sure it all stems from the starter button/kill switch contacts. Mine was a real problem for a while but if you use the kill switch to turn the bike off the action constantly cleans the contacts. I have pulled mine to bits and used contact cleaner and that works for a while, but operating the switch each time you start and stop the bike makes a big difference.
Stevo17 is offline
post #10 of 12 (permalink) Old 03-29-2019, 11:37 PM Thread Starter
Maaaaybeee
This youtuber had his starter replaced and still had the cold start issue. Although he had the dealer replace it the 3rd time and haven't had the chance to really test it.
Nemesis is offline
Could someone post the Dct reset procedure please mike5100 Engine and Technical Discussion 25 10-09-2019 01:41 PM
PGM-FI Fault Light Reset ddavenp Electronics 3 02-14-2018 04:56 PM
Engine Oil Level Check - Why such procedure? Claudio Marinangeli Engine and Technical Discussion 8 08-03-2017 04:11 PM
DCT reset smoothes out low speed jerkiness mike5100 Engine and Technical Discussion 12 08-01-2017 04:22 AM
Running In procedure Hub Architecture Honda CRF1000L Africa Twin General Discussion Forum 8 05-18-2016 05:22 PM
