bar ends - what's the point of the clips? - Honda CRF1000L Africa Twin Forum
 2Likes
  • 1 Post By garyh
  • 1 Post By Shadowjack
post #1 of 8 (permalink) Unread 03-29-2019, 04:10 AM Thread Starter
I've just watched a Kaoko video about how to fit their throttle stabiliser and it makes it clear that you have to reconnect the clip on the end of the springy thing that's inside the handlebar. Does anyone know what this internal thing does? I never reconnected it on my last bike, and on my brand new bike when I took the bar end off I'm sure it wasn't connected. I can see it down the tube but it will take some fishing out if it's important.
mike5100 is online now
post #2 of 8 (permalink) Unread 03-29-2019, 06:35 PM
i tried to reconnect them as well, but I think i pulled the spring thingy too much and prolly messed it up.
I'm also wondering what these are as well and what's their purpose.
Cheers!
gvmumbral is online now
post #3 of 8 (permalink) Unread 03-29-2019, 07:08 PM
garyh's Avatar
Should be a weight down in there if you're talking about what I think you are.
When I did my handlebar protection, I had to remove these too and that "springy" clip fastens to the bar weight inside the handlebar grips.
If you can fish it out (with needle-nose pliers or something) and reconnect it to the clip, probably best. But then again, it likely doesn't hurt much if it's loose in there, not a lot of room for it to move around.
But me... I'm too anal to not have it well secured to the clip. I used some pliers and pressed that clip in some so it would hold tighter to the bar weight.
Hope we're talking about the same thing, Gary
gvmumbral likes this.
garyh is online now
post #4 of 8 (permalink) Unread 03-30-2019, 03:56 AM Thread Starter
Yeah we are Gary. I tried fishing it out with some needle nose pliers but it wouldn’t budge. I’m going to have to make up a tool with some cut down fishhooks or maybe two crochet hooks. As I said earlier I’m fairly sure this right side one was not connected when I took the right side bolt out (ie it had been like that from the factory)
post #5 of 8 (permalink) Unread 03-30-2019, 05:27 AM
I think the inside weight has some o rings on it so it wonít move easily. The first time pulling the bar end bolt out it can easily come out of the clip hence why it might seem it wasnít attached from the factory.
First time I did it I was more worried about the force I had to use to break through the load of locktite they had put on the threads!
Kawasaki ER-6N (KIA)
VaraderoTwin is online now
post #6 of 8 (permalink) Unread 03-30-2019, 07:33 AM Thread Starter
Ok Kaoko are sending me a modified bit for the throttle stabiliser. When that comes I will have a go at reconnecting the weight on a spring. If there’s some O rings down there maybe I will squirt some silicone lubricant in first. I still don’t understand why some weights to stop harmonics need springs clips and o rings. The handlebars work fine with all this stuff disconnected
post #7 of 8 (permalink) Unread 03-30-2019, 07:59 AM
https://www.partsfish.com/oemparts/a...bar-top-bridge
Honda wouldn't spend the money to put on weights made of 8 different parts if they didn't think they were needed. Take them out and give us a report of what it feels like!
Dan P Smith likes this.
Shadowjack is offline
post #8 of 8 (permalink) Unread 03-30-2019, 02:43 PM
-mek-'s Avatar
I had to remove the clips when installed the Barkbusters. No issues about that.
-mek- is online now
Bar Risers Tinpot Honda CRF1000L Africa Twin General Discussion Forum 32 04-13-2018 02:27 PM
DCT - rear brake moved to Left Handle Bar Ozav8r Engine and Technical Discussion 33 11-08-2017 10:02 AM
Holan crash bar tjjj2006 Parts and Accessories 58 08-21-2016 12:14 AM
Front Crash Bar Looks Like Headgear PalmBeachSniper333 Appearance & Body 15 06-01-2016 01:43 AM
New lower crash bar tjjj2006 Parts and Accessories 3 02-11-2016 05:56 AM
