Oil pan torque specification - Honda CRF1000L Africa Twin Forum
post #1 of 5 (permalink) Old 11-30-2019, 05:03 PM Thread Starter
I am planing to remove the oil pan of my AT due to broken pan so what is the specifications torque required for the bolts of the oil pan ?
Turmoil is offline
post #2 of 5 (permalink) Old 12-06-2019, 01:33 PM
Wish I could tell you. I've been scouring the service manual, but can't find anything other than they tell you to remove the bolts in a criss cross pattern in 2 or 3 steps. It says nothing about re-installing it, the gasket, or anything of the sort.
I'm thinking there may be a hairline crack in my pan as well, so I've also been waiting to see if someone chimes in with any info on this...
Emway is offline
post #3 of 5 (permalink) Old 12-07-2019, 10:03 AM
What many, many, many people don't realize is that Honda, at least, uses standard torque values for like-sized "standard" bolts. They put a chart in the front of their manuals for the various sizes. Only if the bolt is special in some way will the torque value be specifically called out.
The oil pan bolts are bog-standard 6mm x 28mm flange bolts. The chart says all bolts this size should be torqued to [12nm, 1.2kgm/m, 9lb-ft]. Some people say that seems a bit high, but proper torqueing is a skill.
Shadowjack is offline
post #4 of 5 (permalink) Old 12-07-2019, 10:46 AM
Ghostrider.1127's Avatar
10 to 12 NM , gasket will be sealant bond
my garage: Honda cbr1000rr 04 - cbr1000rr sp 14 - cbr1000rr sp2 17 - cb1000r 15 - cb1000r+18 - vfr1200f 11 - cre500SM - Goldwing GL1800 2018 -ATAS DCT ES 20 - NC750X DCT 19_- BMW S1000r 18 - Suzuki gsx-s1000 16- gsx-s 1000 19-- gsxr 1000 k2-k5 - Yamaha mt10 16 - mt10 SP 17 - mt09SP 2018 - tracer 900 2017 - aprilia tuono 1100 factory- Zero SR 16 - Kawasaki H2 SXSE 19 - KTM SD 1290 GT 19 ,Few (12) gsx-r sacs 88/92
Ghostrider.1127 is online now
post #5 of 5 (permalink) Old 12-09-2019, 02:06 PM
I'm one of the many, many, many that wasn't aware of this.
It's the first Honda I've owned.
Thanks for the info, gentlemen. Much appreciated.
Emway is offline
