Thread Tools |
Replacing front caliper bolts?
Do people change the front caliper bolts every time the calipers are removed,as Honda say you should,or not?If not,what torque do you use on the old bolts when refitting? I am wondering whether to reuse or replace with some other type such as Pro Bolt when I need to remove the calipers.
Sponsored Links | |||
Advertisement |
Good question Stormcat, yes in the Workshop Manual on page 19-18 it says
"Install and tighten new brake caliper mounting bolts to the specified torque" "45Nm"
What it doesn't say is whether they should or should not be replaced each time.
I'm sure this is just the Manufactures being ultra cautious.
In reality this is impractical, as motorcycle workshops would need to carry thousands of dollars worth of just Caliper Bolts, let alone the tire shops as they also need to remove the calipers every time you fit a new tire or get a front flat.
I myself have had the OE bolts off more than a dozen times for different reasons, never replaced bolts and no problems.
The Burger.
So do you torque the old bolts to 45nm ?
Advertisement |
I do. Five or six times so far. I torque to spec with LocTite 242. I do have a new set of bolts on hand, but have not used them yet.
Angels Camp, CA
You don't need to remove the calipers to remove/install the wheel. Just give the bottom of the forks a twist separating the calipers and the tire will squeeze out/in between them.
Simple answer YES,
The Burger.
Previous Thread
Next Thread
Thread Tools | |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Are handlebar bolts M8 or M10? &a torque settings | pjm | Engine and Technical Discussion | 1 | 05-14-2017 07:52 AM |
AT front suspension | MikeCK | Wheels, Tires, and Suspension | 9 | 02-23-2017 10:22 PM |
Brake disc bolts | xsilvergs | Wheels, Tires, and Suspension | 9 | 12-18-2016 12:01 PM |
Torx bolts | Perspicacious | Honda CRF1000L Africa Twin General Discussion Forum | 4 | 10-05-2016 11:41 AM |
Front fender | marekm | Appearance & Body | 9 | 03-08-2016 09:13 AM |
Posting Rules | |
