Tool to remove front axle on the road or trail - Page 2 - Honda CRF1000L Africa Twin Forum
 12Likes
post #11 of 15 (permalink) Old 03-27-2019, 01:45 AM
black99S's Avatar
Originally Posted by superfunkomatic View Post
Motion Pro tools work well - I have the Rugged Roads fender riser, so I didn't even know there was any kind of clearance issue. I use the stepped Motion Pro 12/13 wrench for the pinch bolts (it's a tapered wrench that seems to work better on those bolts).
I also use the axle tool for the other side to help remove the axle without banging away on the threaded side.
Just leave the pinch bolts tight when you loosen the axle nut - no need for that fancy Motion-Pro hex tool thingy. Then loosen the pinch bolts and with the axle nut still on but protecting the outer threads bang the axle out with the palm of your hand or a rock or stick... then stick a screwdriver through the cross-hole and pull the axle out.
When tightening the axle, finger tighten the axle nut, then tighten the off-side pinch bolts to clamp the axle, then torque the ale nut. Loosen the off-side pinch bolts, torque the nut side pinch bolts, pump the forks to get things aligned, then finally tighten the off-side pinch bolts.
It's a fast and easy job to remove the front wheel if you also remove the lower fender bolts and pivot the brake callipers out to clear the front tyre as you drag it through.
MPNM likes this.
black99S is online now
post #12 of 15 (permalink) Old 03-27-2019, 10:50 PM Thread Starter
OP here. So I ended up buying the 22mm Motion Pro combo lever. It just clears the front fender and so will work.
I already had the 27mm Motion Pro combo lever for the rear.
I need to learn the procedure for removing the front wheel. I've done it a million times on my KLR and dirt bikes, but the lower fender and dual front discs on the AT are new to me.
MPNM likes this.
worstell is offline
post #13 of 15 (permalink) Old 03-28-2019, 12:45 AM
Niceee! Good to know.
Nemesis is online now
post #14 of 15 (permalink) Old 03-28-2019, 11:05 AM
superfunkomatic's Avatar
Yep. Fair enough. The axle tool is a nice to have when things are gunked up or stuck together. Otherwise, yes that procedure is pretty much the best way to get things off and back together. There's not much of a weight penalty for carrying another screwdriver as you mentioned or this axle tool. Both will do the trick.
__
__
superfunkomatic is offline
post #15 of 15 (permalink) Old 03-28-2019, 11:14 AM
Rubicon Al's Avatar
The front axle nut is 22mm. What are folks carrying with them on the bike to remove the nut on the roadside or trail?
I want to get a combo tire lever axle wrench like the Motion Pro T6 or Tusk, but it looks like there may not be enough clearance for it. The fender is very close to the nut, and is a welded post. Does anyone have the combo lever, and is there enough clearance?
I have a 1/2 inch drive 22 mm socket that I use in the garage, but would prefer not to carry it.
I have a DRC tire spoon/axle wrench for that application, it works with no clearance issues. Now, it is steel, and heavier, but fact is a steel spoon is better than an aluminum one any day, the co-efficient of aluminum sucks when changing or repairing tires, and the polished DRC slides nicely.
And if you're on the trail, spit makes it even slicker!
MPNM likes this.
Rubicon Al is offline
Anyone remove the gas tank warning stickers? Numbercruncher Honda CRF1000L Africa Twin General Discussion Forum 16 06-19-2018 11:49 AM
Anyone remove parking brake for hand guards? Bless The Rains Honda CRF1000L Africa Twin General Discussion Forum 8 05-03-2018 03:19 AM
Colorado Trail System - Trail Finder pvanryn Off Topic Discussion 3 03-22-2017 08:19 PM
Leading Front Axle? Paige Wheels, Tires, and Suspension 3 02-14-2017 07:14 AM
Front Axle Sliders frostbitevinnie What Did You Do To Your Africa Twin Today? 4 07-24-2016 02:08 AM
