Bar risers- longer brake & cable Atas - Honda CRF1000L Africa Twin Forum
post #1 of 9 (permalink) Old 05-18-2019, 09:05 AM Thread Starter
Atas dct Has anybody increased the length of hose from master cylinder to joint on the frame, and new handbrake cable, any ideas would be welcome
garryh1 is offline
post #2 of 9 (permalink) Old 05-21-2019, 07:18 PM
I replaced the DCT parking brake cable with a longer one made from a new OEM parking brake cable. Motion Pro out of Loomis CA USA did the actual cable job although the process was done through my local bike dealer. The sizing was just right for an additional 2"+ rise. My service order number #214843 in case they can produce the same thing from their notes. Confirm Africa Twin DCT parking brake job from that service order number. I haven't done anything on hydraulic hoses, but lots of companies willing to make custom brake lines so that shouldn't be a problem. Would appreciate hearing from anybody that can recommend somebody for longer hydraulic lines.
nurber3 is offline
post #3 of 9 (permalink) Old 05-22-2019, 02:18 PM
I installed 3/4 bar riser with the stock cables & works perfect, I could of installed 1 with the stock cables 👍
Desert rider is offline
post #4 of 9 (permalink) Old 05-23-2019, 05:11 AM Thread Starter
The Atas brake line from the master runs into a joint black that attaches to the frame, so is not a standard banjo to screw hose connections, Ive had many braided hoses made over the years, but not sure how to proceed on this at the moment! Many thanks for replying
garryh1 is offline
post #5 of 9 (permalink) Old 05-23-2019, 07:10 AM
I have this problem as well. Wanting to fit 2" risers but top brake hose is too short.
I wonder if the hose from an ATAS might do it. I believe the bars are higher.
If anyone has both at hand a quick measure up would be useful.
Z
2016 AT manual. 2005 TA. 1949 Scott 600.
zarafah is offline
post #6 of 9 (permalink) Old 05-28-2019, 09:24 AM Thread Starter
Mine is the Atas, and need to extend to put 1 1/2 risers on, Ill measure length for you if you require it
garryh1 is offline
post #7 of 9 (permalink) Old 05-28-2019, 10:28 AM
Yes please.
Z
zarafah is offline
post #8 of 9 (permalink) Old 06-10-2019, 08:51 PM
FWIW, part numbers are different for Adventure Sports and non Adventure Sports models for this brake hose. I measure the non Adventure sports models ( part #45125-MJP-G61) hose at about 17" ( 43CM ) including rectangular fitting on frame to center of banjo. Can somebody with ATAS measure the length of this hose from same locations. Thank you
nurber3 is offline
post #9 of 9 (permalink) Old 06-15-2019, 09:29 PM
I measured the ATAS front brake hose today at a dealership and it might be 1" (25mm) longer max. Hard to tell with hose on bike. It looked like the banjo on ATAS wasn't a full 90 degree like the non ATAS which will get you a little extra length as well as this wastes length at least on my '16. Not a very expensive hose so if somebody wants to try, perhaps I will.
nurber3 is offline
Worth a watch. 😳😳😳 Gandalf Honda CRF1000L Africa Twin Videos 7 05-24-2019 01:13 PM
Hepco & Becker Handguards on ATAS with 20mm Risers. garyh Parts and Accessories 1 11-22-2018 09:23 PM
New owner 😊😊😊 Dandemann8 New Member Introductions 2 04-27-2018 02:35 AM
Longer DCT parking brake cable ? nurber3 Parts and Accessories 0 04-04-2017 01:39 PM
Bar risers and front brake line bend Joburble Honda CRF1000L Africa Twin General Discussion Forum 3 02-07-2017 04:36 AM
