Wiring a pair of 10W LED driving lights - Page 2 - Honda CRF1000L Africa Twin Forum
 3Likes
post #11 of 21 (permalink) Old 11-15-2018, 03:52 AM
Originally Posted by Squirrelly View Post
I'm beginning to like it here....
I'm chopping in my 2015 Tiger 800 XCx for a 2018 manual AT which is being delivered next week.
I removed a pair of Triumph LED fogs from the Tiger to sell on eBay but just read this thread.
I'm thinking if I buy a bracket from Rugged Roads
I could use the Tiger LEDs?
Can I take;
1. A 5A fused feed from the battery to a Rugged roads OEM Honda fog light switch then directly to the lamps?
Or
2. Would it be better to feed directly from a switched terminal on a PC8 directly to the lamps so always on when ignition is on?
Is option 2 legal in the UK?
Also, can you buy a PC8 in the UK?
Ideas? Advice?
You can also provide power using the Option connector behind instrument panel; there you'll find switched power AND the wire for the fog light signal on dash so that when you switch on the fog lights you'll have the indicator in the dash.
deltabi is offline
post #12 of 21 (permalink) Old 12-30-2018, 11:13 AM
Hi, please explain, what should be connected to this wire? "Positive" when fog lights are turned ON?
Name:	jungtis po lempa.jpg
jaar is offline
post #13 of 21 (permalink) Old 12-30-2018, 11:21 AM
Yes. The "exit" from the fog light switch should be connected also to the black/blue wire of the option connector to have the dashboard fog light to turn on when you hit the lights.
jaar likes this.
deltabi is offline
post #14 of 21 (permalink) Old 12-30-2018, 11:30 AM
I just purchased my AT 2018. Maybe you know, how many amperes this connector can accept? I want to connect GPS and LED lights to it. Is this connector fused and where is the fuse located?
jaar is offline
post #15 of 21 (permalink) Old 12-30-2018, 12:34 PM
I'm running exactly the same things on my 2018 AT: a Tomtom Rider and the LED lights amperes (Koso Aurora) are powered from that connector without any problems. The LED lights uses about 2 plus another couples for the GPS. All options connected to the option connectors are fused with a 10 amps fuse under the driver's seat (OP FUSE). I wouldn't use 10 amperes on that wires, but i think 4-5 amperes are ok.
jaar likes this.
deltabi is offline
post #16 of 21 (permalink) Old 01-02-2019, 06:00 AM
Looking to install a set of LED auxiliary driving lights on my 2017 Africa Twin. I am using the PC8 unit to control the electric supply but wanted to use the Skenedesign IQ-275 unit to alter the brightness when the high beam lights are not on, i.e daylight. This unit needs a connection to the high beam to switch the brightness up, but I have just read that the feed to the high beam lights will not trigger the device because of the LED lights. Has anyone ever used one of these units and where can I take a 'hot' feed to trigger the high beam brightness, assuming it does work.
Peter
Omsracer is offline
post #17 of 21 (permalink) Old 01-02-2019, 02:41 PM
Greg the Pole's Avatar
i've done a similar set up on my super tenere.
Looking at the AT repair manual, page 567. The headlight driver has four wires. the HB does have it's own wire. One would assume it's a 12V signal for the HB trigger, and be sufficient for what you need to do.
Greg the Pole is offline
post #18 of 21 (permalink) Old 01-20-2019, 08:37 PM
Hi Everyone,
Hoping one of you will be able to help me out and this post seemed like the right place.
I'm getting the Eastern Beaver 3cs kit for some electrical accessories.
However, I have a set of Acerbis Vison Led handguard lights (2x4watts) that I want to install, and at a later stage might add or replace with some real fog lights from Denali. So for now, I want to hook up the Vision's to the front option connector (that will be the only thing I run from that and will give me the chance to open up the front end) and I want them switched via the Honda OEM fog light switch.
The Vision kit only comes with plain + and - wires from each, with no connectors. I've attached pictures below. The wiring guide provided shows how I would wire them if I used the crappy switch they come with.
But how would I go about connecting them to the front option connector and using the OEM switch? I assume I need to buy a 4 pin connector for the front option connector, but what about connecting the OEM switch? Do I need to buy a connector for this to wire with the rest or do the led wires go to the switch and then the switch wires go to the connector? Bit of a newbie when it comes to wiring but I have a soldering kit and crimpers at the ready and been practising lately lol. Would very much appreciate a clear explanation or a helpful easy to read drawing if anyone has one handy...
Thanks very much in advance.
VT
Kawasaki ER-6N (KIA)
VaraderoTwin is offline
post #19 of 21 (permalink) Old 01-20-2019, 08:40 PM
Originally Posted by VaraderoTwin View Post
Hi Everyone,
VT
Now with pictures.
ID:	46521   Click image for larger version
ID:	46523   Click image for larger version
post #20 of 21 (permalink) Old 01-21-2019, 03:48 AM
Hi Everyone,
VT
I think I've already answered to this precise question (by you!) here: https://www.africatwinforum.com/foru...tml#post294253
Just replace the fog lights at the left of the schematics with your handguards light.
deltabi is offline
LED Signal Lights EZStreet Electronics 37 06-12-2018 11:23 PM
Aftermarket Crash Bars w/OEM LED Lights Afrika2 Parts and Accessories 4 06-30-2017 08:28 AM
Wiring aux lights with no fog switch crstep Electronics 2 05-16-2017 12:28 PM
AdMore Top Case LED Bicolour Lights superfunkomatic Parts and Accessories 1 02-19-2017 12:21 AM
DENALI DM DRIVING LIGHTS for sale Watchman Parts and Accessories 5 05-18-2016 03:35 AM
