USB power in dash - Page 2 - Honda CRF1000L Africa Twin Forum
 3Likes
post #11 of 24 (permalink) Old 09-14-2017, 06:54 PM
Root's Avatar
There is this answered question on the page. I think this is for the combo, but the individual plugs are 1.125". :
Question:
What are the outer dimensions of the face plate? L x w
Answer:
2.345" wide x 1.67" high. Mounting holes are 1.91" center to center. Mounting hole(2) diameter is 0.165". You will need to cut a 1.125" diameter hole for the device. I use a hole saw chucked up in my cordless drill. I measured all of these dimensions with my dial caliper so they are dead on. You can actually mount the USB charger socket without the mounting plate by utilizing the lockwasher provided with the unit. This will require that you use a hole saw the will accurately cut a 1.125" diameter hole.
Root is offline
post #12 of 24 (permalink) Old 09-14-2017, 07:55 PM
I'm still having a hard time understanding why this is a good idea when the 12V receptacle (OEM of aftermarket) is easy to fit and the flush dual-USB adapters that go in that receptacle cost $6.
ablock is offline
post #13 of 24 (permalink) Old 09-14-2017, 08:55 PM
joebiker25's Avatar
Can the power for the Honda aux outlet be wired to the headlight or does it have to be routed to the battery? wiring noob :-(
Cuchulainn likes this.
joebiker25 is offline
post #14 of 24 (permalink) Old 09-14-2017, 08:57 PM
There is an open accessory port under the front cowl that the aux outlet wiring connects to. It's very simple, once you have the fairing off (which isn't that simple).
ablock is offline
post #15 of 24 (permalink) Old 09-15-2017, 04:35 AM
I have one Dual USB with intergrated voltmeter mounted in the hole for accessory 12V and a 12V outlet just below on a plate attached to the bike via the USB socket.
Both wired to my PC-8
ctbr is online now
post #16 of 24 (permalink) Old 09-15-2017, 12:18 PM Thread Starter
I suppose my idea it to be able to use both the lighter socket and USB at the same time...
encoad is offline
post #17 of 24 (permalink) Old 09-16-2017, 01:13 AM
Did you remove your tank to run the wires for these two items? Did you splice them together and only run one + and - to the battery? Even 16 gauge wire can handle 5 amps which should be plenty for USB charging and the voltmeter.
I just hooked up my PC-8 today but the multi stranded wire seems kind of fragile where the screws on the PC-8 hold it in place. I'd like to add something like this item below which may work for the OP as well. Given how light weight it is I may be able to get it to mount to the cross bar on the windscreen. I cut snake the wires in the groove around the instrument cluster and place a layer of tape over that seem and it will look good enough for me.
https://powerwerx.com/two-hole-panel-mounting-plate
https://powerwerx.com/two-hole-panel-mounting-pod
NC
Numbercruncher is offline
post #18 of 24 (permalink) Old 09-16-2017, 10:35 AM
Olias's Avatar
I got this off Amazon for $15
https://www.amazon.ca/gp/product/B01...?ie=UTF8&psc=1
Your attitude determines your altitude.
Olias is offline
post #19 of 24 (permalink) Old 09-16-2017, 11:24 AM
Originally Posted by Olias View Post
Did it fit comfortably into that opening or did you have to really work it in or grind the opening a little larger? I tried to fit one that had a collar on the back of it but it felt like I would break the plastic opening. There is also no way I would be able to attach the collar from the inside either. But if it is tight enough the collar may not be needed and I'd probably put a little bit of silicone around the edge anyway for water proofing.
I assume this is the place for the Honda 12 volt connector as that is what it looks like?
NC
post #20 of 24 (permalink) Old 09-16-2017, 01:51 PM
Olias's Avatar
NC
Yes... I had to take a small half-round file and remove about 1mm for it to fit. That was easy.
The more difficult part is taking the cowling apart to wire it and tighten the plastic shaft nut.
I should also say that it charges my iPhone 7 really fast. For example from starting at 50% up to 100% in about an hour.
Olias is offline
Auxiliary harness for 12V socket and USB [email protected] Electronics 20 12-21-2018 06:39 AM
Blown 12v Accy Fuse from USB Charger Greg Electronics 4 09-14-2017 12:25 PM
Two dash switches? encoad Electronics 2 09-14-2017 10:16 AM
12V Socket for battery tender and phone USB? sitralocre Electronics 6 04-19-2017 12:34 AM
Thoughts on the Dash? Paige Electronics 2 07-11-2015 12:01 PM
