POLL: Lithium-ion Batteries and Battery Tenders - Page 2 - Honda CRF1000L Africa Twin Forum
 8Likes
post #11 of 29 (permalink) Old 02-11-2019, 07:28 PM
There is a specific charger for the battery in the Africa Twin. its not cheap - but it is available to buy from japan.
https://japan.webike.net/products/23829085.html
30th anniversary DCT 'Sport.
Motobiker is online now
post #12 of 29 (permalink) Old 02-14-2019, 09:25 PM
dascooter's Avatar
Using a Battery Tender Jr. that has a lithium setting. Have a lead permanently attacehed to the battery. When I can ride regularly I won’t use it. But when I know the bike will sit for extended time, I leave it connected.
dascooter is offline
post #13 of 29 (permalink) Old 04-13-2019, 01:06 PM
Originally Posted by dascooter View Post
Using a Battery Tender Jr. that has a lithium setting. Have a lead permanently attacehed to the battery. When I can ride regularly I wonít use it. But when I know the bike will sit for extended time, I leave it connected.
I just connected a Tender Jr to my new 2018 ATAS (painful and somehow lost the negative screw but had a spare). (I have a habit of keeping a tender on my battery and get 8-10 years out of them).
Is it ok to use a regular Tender Jr on this battery?
It just says:
Perfect for charging all 12-volt lead-acid, flooded or sealed maintenance free batteries (AGM and gel cell) and safety timer-80 hours
desmo907 is offline
post #14 of 29 (permalink) Old 04-13-2019, 01:33 PM
It just says:
No, it probably isn't. even slightly OK. Lead acid chargers are designed to deliver high current at low voltage and then taper off to a trickle, whereas a lithium battery at low voltage needs a controlled low current charge until it reaches 12.8V.
Sounds to me like your battery charger is one of the 'clever' ones.. but not clever enough to recognise the battery type. so.. plug it into a Lithium and it will treat it as though its a Lead Acid.. and that could easily end with a destroyed battery that will have to be replaced.
post #15 of 29 (permalink) Old 04-13-2019, 01:48 PM
Thanks.... I see Tender makes another that does ALL batteries... best I pick that up.
desmo907 is offline
post #16 of 29 (permalink) Old 04-13-2019, 02:15 PM
The original poster had me thinking when he suggested that keeping a lithium battery indoors may be too warm for it.
Honda sell their bikes to countries where temps exceed 34C for months on end and the bikes are ridden in these conditions with the addition of engine heat so I would imagine that the inside of a dwelling with heating on would be unlikely to have any detrimental effect.
I suppose cheap lithium would possibly be dodgy if the quality control was lacking.
MildlyInterested likes this.
skimmer is offline
post #17 of 29 (permalink) Old 04-13-2019, 02:23 PM
They know heat
Agreed. And Japan itself regularly exceeds 35C in the summer, so it's not as if Honda is culturally blind to high-temperature environments.
MildlyInterested is offline
post #18 of 29 (permalink) Old 04-13-2019, 06:08 PM Thread Starter
garyh's Avatar
I was just talking about lithium battery storage in general - what I read and found; most of it not specific to motorcycles, just the batteries.
And *ideal* scenarios.
But the takeaway from my research is that these things are fairly bullet proof and amazingly resilient. Thus my idea just to leave the thing alone, not even bother with trickle charging.
The battery on my ATAS is probably the lowest thing on my list for maintenence. I plan to just flat out leave it alone and see how well it behaves over the years (maybe disconnect the neg. lead for winter storage). I'm guessing the difference between going crazy and storing away from the bike in ideal temps at ideal charge levels makes little real measurable difference. But that's just me.
Gary
garyh is offline
post #19 of 29 (permalink) Old 04-13-2019, 07:51 PM
Gary
Be interesting to see how the European bikes deal with the winter hibernation considering that they come equpped with an immobiliser, which I presume is active and (also assume) places a small drain on the battery. If after 20 weeks of not being touched the bike fires up without undue extra effort, there's your answer.
I believe this immobiliser isn't standard in the US.?
post #20 of 29 (permalink) Old 04-13-2019, 09:38 PM Thread Starter
garyh's Avatar
If you're worried about any draw on the battery, just disconnect the neg. lead - as I did this winter and intend to do - as my only battery routine for foreseeable future.
It takes just a few minutes--the battery is so easily accessible.
Personally, I'd play it safe and disconnect it.
Gary
garyh is offline
Lithium battery suggestions? G20 Honda CRF1000L Africa Twin General Discussion Forum 12 05-20-2019 05:54 PM
CRF1000L Africa Twin Transmission Options [w/Poll] Adventurer Engine and Technical Discussion 21 07-13-2018 06:53 PM
Lithium ION Batteries Geddy Boy Engine and Technical Discussion 8 04-20-2018 06:45 PM
Lithium Battery on the ATAS BigKev Electronics 9 12-08-2017 04:06 PM
Poll: Have your spokes deteriorated? Niterunnr Wheels, Tires, and Suspension 6 07-13-2017 04:32 PM
