Oxford heated grips - a tale of woe... - Page 2 - Honda CRF1000L Africa Twin Forum
 3Likes
post #11 of 27 (permalink) Old 01-15-2019, 08:56 AM
Oldtech's Avatar
I worked as a Honda tech for a number of years. We always installed them using grip glue. When it's wet is actually acts as a lubricant to help slide them on but you have to act fast. As previously stated the glue bond can be broken with compressed air. My AT came with them dealer installed. Not how I would have done it but it works so I'll leave them alone for now.
Oldtech is offline
post #12 of 27 (permalink) Old 01-15-2019, 10:44 AM Thread Starter
Squirrelly's Avatar
All done. The right grip has now been put on dry without any glue and the struggle I had to force it on should hopefully ensure that it's not going to move - fingers crossed...
I've uploaded pics of both grips fitted and one of the right one before fitting to show both the plug and label.
ID:	46449   Click image for larger version
ID:	46451   Click image for larger version
Squirrelly is offline
post #13 of 27 (permalink) Old 01-15-2019, 11:21 AM
roy826's Avatar
I had the same issue with throttle side grip and their super quick dry glue. I was half way on when it dried. I carefully took a super thin small long electronics screw driver and worked it up in between the grip and throttle tube breaking the super glues hold. With the screw driver sill in place creating a small gap I sprayed some soapy water up in the gap. Let is sit a few minutes and was able to twist the grip the rest of the way up onto the throttle tube. Once on I didn't even have to wait for the soapy water to dry the grip wasn't moving. It'll have to be cut off if ever removed.
Left side was glued on with their slick super glue and slid on the bar way too easy. I expected it to come loose in time but after 2 months both grips are working fine and have not moved.
2017 CRF1000 DCT candy apple red
roy826 is online now
post #14 of 27 (permalink) Old 01-15-2019, 12:04 PM
The trick is to have them tight when they have been hot for a while.
I have fitted one which was tight when fitted but when hot (and presumably softened and expanded) it turned on the bar. Good luck.
BigKev is offline
post #15 of 27 (permalink) Old 01-16-2019, 08:29 AM
Originally Posted by roy826 View Post
...took a super thin small long electronics screw driver and worked it up in between the grip and throttle tube breaking the super glues hold. With the screw driver sill in place creating a small gap I sprayed some soapy water up in the gap.
This how I've removed grips for years, except I spray brake cleaner into it and wiggle the screwdriver to let it spread. I just use brake cleaner because it dries right up. I use it for lubricant when I put them on as well. I've never had to use glue before, until on this left Oxford.
Shadowjack is online now
post #16 of 27 (permalink) Old 01-16-2019, 08:49 AM
roy826's Avatar
Me either the left oxford seems to be a tad to big in diameter from what I felt. I'm surprised my left one is still holding especially with that super glue they provide in the kit.
Best heated grip glue I have ever used is Yamabond7 made by Yamaha. Very good grip glue and they spec it on their factory heated grips and use it on their non heated grips as well. Very good stuff! If my left oxford eventually twist loose I will reinstall it with Yamabond7.
post #17 of 27 (permalink) Old 01-16-2019, 09:56 AM
Thanks for putting up the pics, but I can't tell what connector type that is?
What did you plug it to? I planning on connecting my oxford grips to the Eastern Beaver 3CS so would it just be a matter of cutting off the Oxford connectors and replacing with those from the 3CS? Thanks,
VaraderoTwin is offline
post #18 of 27 (permalink) Old 01-16-2019, 11:37 AM
bbanker's Avatar
Originally Posted by Africagaz View Post
Solution don't glue the throttle side at all,i haven't and it does not move.
What he said
bbanker is offline
post #19 of 27 (permalink) Old 01-16-2019, 03:02 PM Thread Starter
Squirrelly's Avatar
The connectors between both grips and the controller are plug 'n play. The only DIY job you'll need to do is at the battery end. The grips are, according to Oxford "UK Specific". As I said the original install was by the dealer so I can't comment on the battery end fitting on my bike sorry.
If it helps, all the YouTube Oxford install videos show the old style white non-weatherproof connectors.
The latest connectors are round black plastic with a sealing gasket and a screw collar to hold the male and female together.
post #20 of 27 (permalink) Old 01-16-2019, 06:12 PM
Ok got it thanks. So grips to controller and then controller has the leads to the battery, meaning Iíll just cut those off and plug into the 3cs once I connect the included connectors from eastern beaver. Should be ok then
Kawasaki ER-6N (KIA)
Oxford Heated Grips Ti04 Parts and Accessories 14 10-07-2018 08:26 AM
A tale of self inflicted woe pjm Electronics 0 08-20-2017 12:03 AM
Help fitting Oxford heated grips Philipw New Member Introductions 11 05-15-2017 01:14 PM
Garmin 590LM, Spot beacon and Oxford Grips Canadarider Electronics 9 04-09-2017 01:38 AM
Oxford Heated Grips artbone Electronics 8 04-04-2017 12:18 PM
