1 - 6 of 6 Posts
hey guys hows it going?
so i wanted to test out my new pump i bought and pluged it into my AT's 12v port and well nothing happened.
so tested the port with my multi meter and there is no juice.
now i hear mutterings that the fuse is in a hard to reach place.
where would that be and what do i need to do to reach it so i can check it.
You've deffo blown the fuse if you've attached a pump to it, and don't be going on racking up the fuse or you'll blow something ever more expensive than a fuse.
My stop and go mini compressor works fine from the battery. I have a fused Charging lead connected direct to the battery that I use to connect the compressor to. This means that you can use the compressor without ignition on and hence without lights on. Cant use it for too long otherwise you should run the engine to keep battery charged. I don't know what current the compressor pulls but the compressor cable is smaller diameter than the charging connector so all is well in my book.
1 - 6 of 6 Posts
