Just to point out that the past 10 days or so have seen an unusually long "Golden Week" national holiday, and business in Japan sort of shuts down for most of that period. He's probably back at his desk and working through the backlog.
Thanks for your answers, but I had to join facebook just to try and chat and no one was there. Also, to email him is a hassle because you have to join and create an account which I don't understand since I have enough accounts already. Ok, I get it, he's a small business, but other small businesses I've dealt with are much easier to contact. Some what disappointed so far.
I do understand your frustration - I am very impatient for things to arrive - but perhaps there has been some misunderstanding here, because his email address is on the contact page. All you have to do, as far as I can see, is use that.
Anyway, let's hope that they are able to contact soon, and that the delay is caused by a vacation, rather than something serious.
He's not a fast responder. He does ride motorcycles and has a photography business, which would presumably take him away from home sometimes. When I ordered, the parts eventually showed up, but it's not Amazon.
Ok, finally got an email this morning saying my part has shipped. Yep, it's kind of madding having to negotiate webpages that are not clearly laid out. Nothing on his main page or his shipping page has a tab or label saying "contact". I may have missed it but..... it shipped, so I'll see.
I like the idea of a main fuse block and not having wires hanging going to the battery. The AT is a bike that does not allow easy access to new wires being installed.
I would not connect directly to the battery, use switched power.
You can do your own cabling starting from the option socket behind the instrument cluster: 12V + GPS power; in this case you only need the OEM connector (https://ruggedroads.co.uk/4-Way-OEM-Waterproof-Connector) and then you do the cabling (you'll also need a generic 12V socket).
Or you can install "OEM way", buying the 12V socket kit and the "sub harness kit" (Y cable) which will allow to power a second accessory (GPS). In this case you still need an OEM 4-way connector if you want a "clean" cabling (or you'll cut the Y cable and connect directly the GPS power wires).
So if I use the OEM kit, The white connector plugs into the connector behind the front cluster, Red connector to the 12V supplied and the other connector is for a second port if I want to install, correct?
Not exactly... your last assumption is wrong.
If you need to connect a second accesory with the OEM kit you have to buy the "sub harness kit" (link: https://ruggedroads.co.uk/epages/00...c-407e-8207-580e14387ec5/Products/08U74MJPG50).
The OEM Socket Accessory kit has only one connector, the other white plastic "thing" you see in the images is the fuse holder (and because this will be under the fairings, don't blew it!).... see image below...
The "sub harness kit" (Y cable) add a second option connector that you can use for a second accessory.
Got the fuse block Friday, looks good. I bought the longer extension so I can place FB under rear seat. I will say there is a lot of extra cable to deal with. Will try and post some pics later.
does anybody know, what a fuse is used for the 12V OEM Aux socket (which comes, e.g. with ATAS MY2018)?
On the plug itself (in my case), there is a short information about power output 12V at 2A, so by applying the well known formula for DC, P(power) = U(voltage) x I(current), I assume, that the output power of the OEM AUX socket is approx. 24W. My issue is following --> I would like to use an 12V to 5V "cigarette" adapter to charge my iPhone, which has at the output 5V and is able to supply approx 2.4 Amps, what in turn means 24W (using the formula above again). Under the assumption, that the iPhone will draw 2.1 - 2.4Amps at 5V and fact, that the efficiency of such an adapter or more likely to say a DC/DC Converter is approx 92%. So it means, 24W/0.92=26W.is a power which will be drawn from the AUX in order to charge my iPhone. Assuming, that the board voltage may vary from 11.8 to 12.8V, the current draw from the battery would be approx. 2Amps. What I want to say is, that in my opinion, it should be safe to charge an iPhone from the AUX outlet on the dash, or am I completely wrong?
Do you have some experiences? I am looking for some advice ...
PS: I am also considering to use a rear option connector (6pin white) and to buy this kit from SW-Motech: EVO 2.0 electric top ring (unfortunately I am not able to place any links here)
From MY2018 (standard and Adventure Sports) the OEM aux socket is connected directly in the main loom and not to the option port behind the instrument panel (which had a 2A fuse inline to the socket and is a nightmare to replace in case). Therefore the MY2018 12v OEM aux socket is protected by the 10A OPT fuse in the box under the seat.
I think you will not have any problem using the charger you described in a MY2018- Standard or Adventure AT.
@ all: I have to correct myself. the iPhone charger has two outputs; each can supply 2.4Amps. @deltabi: thank you for your reply. Do you have some wiring diagrams of ATAS MY2018 you can share with me?
Does anyone know the differences between the two sockets for 2016-2017 vs 2018 besides the huge price difference? I assume the connector may be different but can't see how that would decrease the price by as much as it currently is. Thanks
If you are referring to the aux power socket, in the MY2018 they changed the main loom, adding a specific connector for installing the power socket. So it's easier to install it and you don't need to remove the front part of the fairing to have access to the front option connector where the socket it's connected in the MY2016-17.
21 - 36 of 36 Posts
