1 - 12 of 12 Posts
Hi I' m new to the forum. Can anyone give me the proper suspension settings front and rear for a rider of 225lbs (102kg). I would greatly appreciate any help. Thanks
My settings are -- new springs and valving from Cogent Dynamics...
Seriously. With the stock hardware the best setup I got was spring preload, compression damping and rebound damping all maxed out on both front and rear. I'm 190#.
I just spoke with Cogent after talking with them I plan to just do front and rear spring upgrades. I am a 215 lbs rider. I just completed TAT on stock suspension. The only issue I felt I had was the front wheel wanting to wash out on loose gravel/sand. Re-valving, in my opinion, will only benefit riders that will be riding a lot of roots, rocks, washboard at speed. Procycle. I would be interested in hearing what changed with your bike handling after your upgrade.
The bike is transformed.
I don't ride roots and rocks with this bike and don't ever intend to try to treat it like a dirt bike. I mostly try to ride twisty paved roads and scenic gravel and jeep roads.My riding style might be described as fast and smooth but not necessarily aggressive. With the stock suspension I could not stay smooth in the corners. The bike would pitch and wallow. It would not want to hold the line I picked so I would find myself correcting mid-corner.
The Cogent setup is great. The bike feels very well controlled but is never harsh. Riding twisty pavement is now big fun. Local logging roads are a treat instead of being a little sketchy.
There's a review article I wrote for the ProCycle newsletter here --> https://procycle.us/info/newsletters/jun-18-issue.html
Hi I bought the byke not long ago and did not lyke the setting went back to Honda who set its factory original setting a lot better. The setting are indicated in the manuel; they are 3 things to adjust I would suggest to start there and them modify and take notes at each change until you find your setting.
PS the harder may not be the better §
Cheers
I have a 17 DCT and I find the spring rates to be soft. I am not even heavy at 137 lbs. Just dealing with it right now but I do have the rear preload cranked up to 19 clicks in. 2 clicks in on rear rebound and 2 clicks in on compression on the rear. Front seems okay for me on stock settings. Haven't really pushed the bike hard yet however only 500 miles on it.
Hey, where on earth did you find the rear rebound settings? I have no clue where to look for it :S
Procycle,...would like to read the article but the link doesn't work, do you have an updated link
1 - 12 of 12 Posts
