If you can pull off one of those I would absolutely pay you to make one, whatever the post may be. @Relhok said his HoHey doesn't do that, and while the HoHey does look pretty solid, it seems like it would still suffer from the same design constraints as the cheaper one I got from sic. I am thinking about taking it direct to the modulator, but the Honda banjo fitting has a locating pin
which probably isn't absolutely necessary, but Honda undoubtedly put it there for a reason. I thought about splicing into the Honda hose, and maybe I will ultimately do that, but I'm not quite ready for that, especially if I can find a teardrop solution that's solid for the near term.
