I’ve looked all over on how to remove these things. Some say drilling a hole. Just put this pipe on today and mine has screws. Only when screws are removed the things won’t budge to be pulled out. Not concerned if it’s to loud with them out. Plenty of loud Harley’s around here so no one will care. Didn’t want to bend them up trying to hard tugging on them
Am I missing something here? Shouldn’t they just pull out with screws removed?
I got them out! Trick is clamp a pair of vise grips on the end, take a chisel and put it against the vise grip screw and they tap right out with a simple hammer. I did heat them up with a heat gun but probably not necessary.
Sounds so much better and breathes now. Rather have a full system and bye bye CAT. May do that in the end. Lose some more weight.
