1 - 4 of 4 Posts
2017 DCT
If yes, how did it go?
How much, if any mods did you have to make to the mounting bracket, if you have crashbars (like Heed Bunkers)? I'm guessing I will need to make brackets and mount to the bars, but kind of hoping that I might get lucky and be able to use the frame-mount with a minor cut or two.
Happy with the light amount, distance, spread, etc.?
Happy with the wiring?
It looks like these are setup to use a trigger wire from the Hi Beam, if desired, and to actuate, with a switch, as well. Is that the case?
Does the kit come with a switch, or do I need to buy the Honda fog light switch to be able to not run them with the High Beams on?
Guess that is a lot of questions, but if you can answer any of them, it would help.
Cheers!
1 - 4 of 4 Posts
