1 - 4 of 4 Posts
Can someone please tell me if the handlebar bolts are M8 or M10. I am looking to add a ram ball mount and need to know which size. I am loathe to undo the bolts as it seems from another topic a bit of a faff to get them just right. If someone has the correct tightening procedure and torque settings that would be a great help.
Hi,
Maybe who has service manual for crf1100?
Are the same settings for CRF1100 upper handlebar holder socket bolt? Quantity 4. THREAD DIA 8mm TORQUE N·m 32 (3.3, 2)
ROTFL.
Loosen. Move bars. Tighten. Use Allen wrench.
If clamp is centred (gap both sides) before you start the do the same as you tighten.
If clamp is flush one side and gapped on the other, tighten the flush side first.
Dropped your bike? Move bars to steering lock and reef on them to realign rubber mounts in risers and get bars perpendicular to front wheel.
I’ve never used a torque wrench on bars. I do use torque wrench most other places.
1 - 4 of 4 Posts
