Whilst out riding today my ATAS '19 developed a problem where under hard acceleration it lost its gears and thus power requiring me to pull over to the side of the road for the system to find itself again and reset to neutral. This happened numerous times the first time whilst overtaking a car! Putting me and the bike into a dangerous situation.
The bike was in D-mode and Tour. I also tried using the gears in manual and it did the same.
When you say it “lost its gear”, do you mean it briefly shifts into neutral, or up shifts too fast (so from 3rd to 5th for example, and skips 4th)? Does it happen consistently with a given gear (always skips 3rd For example) regardless if manual or automatic?
Ive never had an issue like this, so can’t offer much.
No it just completely looses any gear whatsoever. No gear is displayed it pops a couple of warning lights up for engine, oil etc. but then the engine stays running, I pull over and it resets its self into Neutral and away we go.
Yikes! Sounds like something to demonstrate to Honda under warranty. It seems you have a reproducer, and that helps a lot when describing to the service garage.
For what it is worth Battle, welcome to the Forum.
Cheers double thumper, yer I'm already trying to make contact but with it being bank Holiday and covid excuses in full swing I'm not getting anywhere fast. We shall see what happens when Tuesdays rolls round.
I would also check the wheel sensors - make sure they are not really dirty, damaged or failed. It could be kicking in the traction control and causing this.
AT is going to the dealers next week. Did attempt to solve the issue using a gear reset, it didn't work but thought I would share the sequence to reset the dct gearbox:
1- warm engine to operating temp then turn off bike.
2- Hold D Button and turn electrics on (don't start engine)
3- Press sequence D, D, N, D, N
4- Display should show both Sport/Drive options and a (-) allow the bike to find its neutral which takes a couple of mins.
Well that sux..
I’m guessing the gear position sensor has issues (4th gear from the sound of it). Basically the gear box sensor for that gear is not showing it in that gear so the ECU gets “lost” and you’ll get the “__” double dashes of death on the gear indicator
Too often a problem arises, question asked and then no follow up.
Related Threads
Honda Africa Twin Forum
171K posts
19.3K members
Since 2015
