I have the ATAS fitted with tubeless Alpina wheels and Continental Trail Attack 2 tyres
To the valve stems I have caps fitted which give me tyre pressure and temperature monitoring
I have been running at Hondas recommended pressure of 33psi front and 41 psi rear. These pressures are higher than the recommended pressures for the standard AT which is 29 front and 36 rear.
I always ride tarmac and solo
Over the last couple of months I have lost about 3 psi from each wheel so I topped them up. Next ride I noticed I could feel more road bumps.
I am thinking of dropping the pressures back down to 30 front and 38 rear again
Was wondering if other ATAS owners have played around with pressures and what they have found
Thats interesting.
I am running tubless on SM Pro wheels.
What are other people running as road pressures?
Always thought 29 was a bit low.
Z
I run stock setup (meaning tubes, which I would reaaaaly like to get rid off, but the cost is too high). I follow the OEM recomendation for pressures, that is 33psi/41psi.
