superfunkomaticJust installed the Denali D4 lights and Africa Twin Specfic mounting bar (DENALI Auxiliary Light Mount For Honda Africa Twin CRF1000L '16-'17 - LAH.01.10300 ).
I cut apart the Denali harness and used the waterproof light connections (there are two extra for longer applications) - I only needed two to get under the left side front fairing and into the hole Honda left for wiring their lights on the left hand side. I got tired of monkeying around with the relay and went right to the accessory plug (extra) under the speedometer/dash connection.
Red wire - power
Black wire - neutral/ground
Purple wire - fog return light (connected to the power wire after the switch).
Works great. Fits nicely in the little space under the left fairing and looks meant to fit with the OEM foglight button.
I did the power socket, my GPS and the OEM fog light button all at the same time. Took some figuring to get everything apart and back together. Holy smokes the Denali lights are bright - great for visibility and night riding.
Got the OEM 12v charger, about to order the Denali 2.0 D4 light and mount. Now I need to order the OEM light switch, and figure out what you did for a GPS set up.
Decided a while ago that I was going to do the charger and lights at the same time because I have to pull my AltRider upper bars and headlight guard before pulling the fairing off but this project seems like exactly what I need to be doing (GPS is something I just thought I'd run to the 12V but you seem to have found a better way).
Can you elaborate on process, especially in regard to wiring and whether or not you went with a kit like one would find at easternbeaver.com or really ANYTHING you could share as you're set up right where I need to get to?
Thanks in advance Sensai!
