I'm running a set of PIAA 3.5" LED lights mounted to Heed crash bars. They work really well.
Did you use the wiring harness that came with the PIAA set?I'm running a set of PIAA 3.5" LED lights mounted to Heed crash bars. They work really well.
Below is another option you can consider, or at least possibly see the wiring that was used to connect everything. This is an extract from a previous post of mine on my thread "My AT and Accessories". https://www.adventurebikeshop.co.uk/africa-twin/africa-twin-wiring-loom-for-lights/ is the product I refer to below that I used. If you resell the switch and the power splitter you have you can buy then and then you don't need to worry about the electrics at all!.Did you use the wiring harness that came with the PIAA set?
I also bought the PIAA lights, but want to use it with the Honda OEM switch and also connect it to the dash so that the fog light icon is on when the PIAAs are on. Bought the switch and also the Eastern Beaver front power splitter that is widely recommended here. But I am not sure how to do the wiring when using the Honda OEM switch – e.g. where to connect the switch control positive seen on the PIAA wiring diagram (Honda OEM switch has only 2 wires).
Any help greatly appreciated (it's my first time dealing with motorcycle electronics).
Look here: https://www.africatwinforum.com/forum/201-electronics/32267-my2018-front-accessory-wiring.htmlHi interested in your advice here, im a new AT Owner and plan on adding a few bits along the way. You mention your wiring, but wondered if you can elaberate a bit for me?
Im looking at adding GPS power, USB socket in the factory blanked location and , maybe driving lights like yours. Did you power it all from the socket hidden behind the dash?
Is there a simple wiring diagram you could produce for me?
Many thanks
Where did you get your brackets to mount them to your forks? Also and pictures? Thanks.yours is fairing mounted by the looks???
mine is mounted on the forks... it did just go tink until i swapped the bolts to the top and made a small tweak to the bend in the bracket.. resulted in light being 35mm further back 25 mm higher and absolutely no chance of fowling the mudguard ..
tested on saturday night on a local 4x4 playground in the pitch black ... in the slow and hard to see the headlight projecting forward and the spotty was looking wherever i pointed the handle bars ... awesome for in the ruts and rocky sections ..
