Edit: Solved! See below.
I was just doing some wiring on the capped off accessory connector at the left rear under the pillion seat. That's the one shown in Step 6 in these alarm install instructions.
The hot lead hit the ground and I heard a fuse pop. Turned on the bike and everything works except for the blinkers. Unfortunately I can't find the blinker fuse; it's not in one of the three main fuse packs. I would think the fuse would be the one marked "OP" (optional power), but that fuse looks okay.
Can anyone help me out? I would like to finish this project... :grin2:
Thanks!!
Glad that you found the issue quickly :)
Never mind, I found it. It was the "Clock Run" 7.5A fuse. No idea why.
Actually in the Worksop Manual it says CLOCK TURN 7.5A, so that makes sense as to why it fixed your problem.
The one in the small bank of three is marked Illum Stop 7.5A went on mine and that took out the instruments and turn indicators. My bike is a UK model.
