Well,
I figure I might as well join in on the conversation. Yep, I did the 3M conversion about 15-16 months ago on my '18 A/T - A/S- DCT and it's been flawless ever since. I took my time, constantly red comments on here and checked out many videos on the process. I'd have gone with the Outex system but I figured what the heck, let's try the 3M system. I used 3M 5200 sealant around all the spoke heads and then 3M 4212 (I think that's the number) sealing tape on the rims over all the sealed spoke heads.
My process was to ultra thoroughly clean the rims. Then, use Alcohol to really wipe, in detail around each spoke head and finally, I used a heat gun to really make sure any and all moisture was dissipated from around each one. I got that rim almost too hot to handle. I then applied the 3M5200. The heat made that sealant flow really nice around each head. I let that cure for about 36 hours if I recall.
Then, I heated that rim again. I used a heat gun, not a torch. Then the tape application. Having that rim heated, really caused that tape to adhere. If I wanted to re-position the tape for any reason, TOO BAD, IT AIN'T MOVING! When the tape was finished being applied, I used one of those little steel knurled rollers you use for rolling patches on tubes to really seat that tape in twenty million directions (almost exaggerating here). I really wanted that tape to be seated.
Once done, I made the only mistake in the process. I re-installed the original rubber spoke head protector band. BIG MISTAKE! I later corrected that. But, I installed two brand new Dunlop Trailmax Mission tires at that time too. Man, what a pain in the A$$ that rear one was. I finally got it.
Those tires and wheels have been on there now for around 14 months or more and I've not lost a single pound of air other than ambient temp changes which is normal. I'd do it again in a heartbeat.
Scott
