1 - 7 of 7 Posts
Crash Bars (again - again) - I doubt my HB bars will actually protect my bike
I was at an ADV rally last weekend - part riding, part lectures. One of the lectures I attended was on "The Science of Crash Bar Protection". This was a talk given by Jeremy LeBreton of AltRider. After listening to his explanation of good design principles to be followed in crash bar design (while I am not a mechanical engineer, I do have a solid grounding in mechanics and physics - and his points all made sense to me) I went to look at my Hepco Becker bars that I have on my AT. They violated a couple of good principles:
the bars are partly flattened where they join - this makes production easier, but lessens their strength any time the round tube is flattened
designing the bar so that distance between solid attachment points is at a minimum and that any extensions that are not directly tied to attachment points are at a minimum
I gave my lower engine bars a soft kick and was disturbed (actually I was pissed off) to see how much they flex with just a relatively gentle tap - the bars on the right side actually hit the engine casing with this tap from my foot. I took a slo-mo video (not allowed to upload videos, so if you are interested, you can see them at the link below) to show the flex of the bars. I was giving them a pretty gentle tap with my shoe - nothing like the force they would get when your 525 lb bike hits the ground. There are 3 videos - AT left side, AT right side, and AltRider bars on the BMW GS.
Since there were a lot of other bikes around, I went to find some AltRider bars - the ones I found were on a BMW GS. The same tap did not budge that bar. Note the BMW engine bars are 1.25" vs the 1" of the Hepco Becker, but I noted on the AltRider web site that the lower bars for the AT are also the same 1.25" design as the BMW, so I would expect similar strength.
I am putting my order in for the AltRider bars today. I'm mad that I wasted so much money on the HB bars that won't really work, but I would rather pay out another $600 for bars that will work, than have to pay tons more than that to fix a damaged engine casing that is taken out by the very bars I bought to protect it.
I have no relationship to AltRider - I am just trying to help others not make the same mistake I made.
You can see the videos here: https://www.icloud.com/sharedalbum/#B0h5aDWbrGMmsOS
Nope - nothing loose. I have double checked installation and fastener tightness. I think the main culprit is just the way the bar "loops" up and away from the attachment points - just not enough rigidity in the bar itself given the distance from the frame attachment points.
That's disgraceful. I think you have a definite case for your money back on the grounds of them being 'not fit for the intended purpose'.
Just cancelled my order of HB upper bars and handle bar gaurds. Thanks for the heads up
Sent from my Pixel XL using Tapatalk
1 - 7 of 7 Posts
