Good day fellow AT enthusiasts
I am hoping someone or more can help me with the issue I am having.
I have always had a slight ”wobble” on my front wheel and I put it down to the new tire.
long story short , I removed the tire and found what appeared to be a crack in the rim on the weld.
I eventually got a complete new rim set from Honda and when I opened it , it appears worse than the original rim.
The reason I got a rim was the fear that it was cracked and cause an accident.
If any of you are in the middle of changing your tires , please can you inspect your rims and check the inside of the rim on the weld. I am attaching some pictures of the new rim.
Heli
Heli
