Installed the Denali S4 lights with a Eager Beaver 3cs hook up, lights still won't work. Anyone have a problem with the AT and Denali lights?
Some LED lights are polarity sensitive. Did you hook up the positive and negative wires from the lights correctly - you could try and reverse the connections and see if they go on.
Denali LED lights come with three wires and if you use their premium wiring loom (sold separately) unless you bought a kit,
you cannot mess it up.
If you want to take advantage of the "Data Dim" technology, you also need to have the controller- sold separately.
Pricey but makes the install easy.
Reactions: Cuchulainn
I went with the DataDim and Switch Eliminator kits and that works for the way I want them to operate.
So, I may have an answer to this old post. I installed S4s today. Hit the switch and nothing I figured out after a few minutes there was additional steps on the back of the page. Even though I was using my Eastern Beaver PC8 I had to connect one of the lines to a switched power. Easy enough I just posi-tapped into the hot wire to the battery. This works as the PC8 is a switched unit... Just a thought! Now I have to adjust them!
