When changing the brake fluid do I need to consider ABS ? Or is it a simple purge through at the caliper bleed nipples as per a non ABS bike
If you haven't done so, this is a great time to install brake bleeders with one way ball check valves. Makes the job much easier, cleaner and faster.
Does the one way bleeder screw into the caliper in place of the normal bleed screw. Or is it in the plastic bleed pipe and hence removed after bleeding.
Yep, it simply replaces your normal bleed screw..........think of it as your normal bleed screw with a check ball valve inside.... that is all it is.
