Made the attached chain oiler to simplify the chain oiling. Took 2hrs to completed it, so almost the same time with installation of the commercial version. 50ml oil reservoir is made of a medicine syringe, so it can be slightly pressured. It's not fully painted, so oil level can be checked easily. Still thinking, if oil reservoir locates a bit too hot area (not in contact with metal).
Inside of the flexible hose is 2mm metal bar, so it helps to optimize hose design. Reservoir is easy to fill. "Moustaches" made from cable ties. All the equipments found from my garage.
Yes, you can get oilers in the store, but I don't need the weather forecast features and I don't need the device to feel the direction of the wind either. That's why simple solution is beautiful.
Time will show, how well it works in practice. According to quick test, it fulfilled my expectation.
If it does not work in long term and possible mods to done are not good enough, it takes 2min to remove it.
Drive safely.
Drive safely.
