1 - 2 of 2 Posts
Just set the bike up with the Acerbis multi concept handguards. Drilled out and tapped the Allen socket on the end of the bars holding the end weights on to a 10mm thread and bolted them on. Pretty slick. They seems to fit perfectly with almost no tinkering. Happy Trails in Boise sells a nice adapter kit to help get them fit just right. I used one spacer between the bar mount and metal rail.
Additionally, prior to the handguards, I made some lateral wind deflectors from some 0.22 inch plexiglass. Just cut, heated with a torch and molded. I had done it with the original handguards that stick out sooo far so I may need to make some that are contoured to the new handguards. So far, I believe they do reduce some helmet buffering from the sides, which was bugging me a ton at higher speeds.
Discussion Starter · #2 ·
So I bought some adjustable clutch and brake levers off eBay recently. said they would fit the crf1000, so I thought **** They come in a set for $30 and I broke my break one, why not?
Shipped from China reasonably fast and they are AMAZING. they flex up and adjust so you can find a perfect placement for your clutch. I am super impressed with how nice they are. Fit with the Acerbis handguards with spacers.
1 - 2 of 2 Posts
