This past weekend I took my 22 ATAS off road and had a couple crashes on the right side: first time in some thick sand in a curve and second lost balance and fell on some hard rocks.
The first image shows the location of the direct impact(s). When I got home I noticed that the right side bar was now almost touching the fairing. The second image is a front view that kinds shows the imbalance between the two sides, might be hard to tell. The third image is a close up of the side in question and as you can see it is just a few millimeters away.
I attempted to remove the bars and reinstall just to see if they just got knocked out of alignment. However, when I got to the last step to try to install the bolt and spacer connecting the two sides, this just isn't possible as the right bar at the front is pressed up against the nose of the bike. The last image shows this position. I made sure not to torque any bolts before getting everything into place, so I am sure that isn't the cause. During my initial install I didn't have to struggle at this step.
I am now thinking that for sure the bar was impacted enough to cause a bent deformity. But wanted to run this by the forum and see if anyone who has these bars would have any insight. I am leaning towards replacing the bars, but that kinda sucks that I would have to do this after only a couple of slow speed crashes, albeit the terrain was pretty rocky. At least they seem to have done their job as there isn't any obvious damage to the bike.
